Results 1 to 6 of 6
Thread: Driver side seat belt not working Please HELP!!
    112
    Exclamation Driver side seat belt not working Please HELP!!
    My automatic seat belt just stopped being automatic and im not sure where to start looking to fix it. It just stopping working out of nowhere. Driver side is dead passenger side works fine, any help would be greatly appricated
    Thanks
    Michigan
    813
    mine did the same
    The motor that controls it is behind the plastic interior molding that would be near the rear seat, drivers side, closest to the door. Mine was shot and actually retaining current and draining my battery down. I unplugged the electrical connection to it and have not replaced it yet.
    Oklahoma
    804
    A friend of mine's 35th also hangs the drivers belt just a few inches before stop going forward. You have to sort of help it along. There is a cable in a track that runs that belt and it can get hung. I don't know if it can blow an inline fuse but it might. Otherwise the motor may have died. I haven't been there yet but have helped a few tracks get lubed and working better. Hope this helps some.
    Good Luck.
    Aug 2002
    65
    MAKE SURE THE DOOR IS SHUTING PROPERLY SOMETIMES THAT CAN BE THE PROBLEM
    Fort Smith, Arkansas
    117
    mine was dead when i bought the car. turned out the track was all crumpled up where the gear drive is. i bought another complete retractable seat belt assembly from a salvage yard but when i installed it it didn't work either. turned out the motor was dead so i took my good motor and installed it on the good track. i lubed the track with white lithium grease and haven't had any problems since i did that about a year ago or more.
    its a bit of a pain to work on since the whole back seat has to come out along with the panel on that side of the car along with the trim running along the roof and the pillar.
    112
    Angry
    well the seat belt issue is on hold for now, My fuel pump just decided to quit on me so i have to fix that 1st
