Results 1 to 9 of 9
Thread: Upper cable on TB bracket - cruise control?? (94)
    Memphis, TN
    1,911
    Stupid questions I guess, but here goes... what's the cable on top of the throttle cable for on the late model cars? It runs from the bracket to the front of the DS fender. Is that for cruise?
    Jul 2007
    South IL
    1,574
    can you post a pics please, that will help ensure an accurate answer
    Feb 2003
    Murrysville, PA
    1,276
    Pretty sure that is vacuum assist for the cruise control.
    Jan 2003
    Woodbridge, VA
    5,236
    Yes cruise control.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Memphis, TN
    1,911
    Thanks guys!
    Forked River, NJ
    2,092
    Quote Originally Posted by Tony8470 View Post
    Not vacuum, but a cruise control cable.
    Feb 2003
    Murrysville, PA
    1,276
    Doesn't that go to the vacuum assist that's contained in the fender?
    Forked River, NJ
    2,092
    It's an electric servo....
    From the shop manual:
    Speed Control System
    The speed control system consists of:
    speed control servo (9C735)
    speed control actuator cable (9A825)
    vehicle speed sensor (VSS) (9E731)
    horn relay and bracket (13853)
    speed control actuator switch (9C888)
    stoplight switch (13480)
    deactivator switch (Part of 2B091)
    brake pressure control valve (2B091)
    air bag sliding contact
    The system operates independently of engine vacuum, therefore no vacuum lines are required.
    The speed control servo:
    is mounted under the LH front fender (16005), forward of the wheel.
    connects to the throttle linkage with a speed control cable.
    integrates system electronics, eliminating the need for any other speed control electronic modules.
    Feb 2003
    Murrysville, PA
    1,276
    This is interesting. They must have changed it for the 94/95. Maybe because of the airbag. Didn't the earlier years use vacuum? There is a vacuum line that went from my plenum into the fender. I knew it was for cruise, so I never put it back on.
    Edit: I hope it was for cruise....
  1. guys, help with upper control arm...please!
    By red Supercoupe in forum Technical Forum
    Last Post: 08-03-2017, 12:18 AM
  2. Weird problem... Cruise control?
    By Evan_90SC in forum Technical Forum
    Last Post: 05-14-2009, 09:12 PM
  3. Help with upper control arms
    By 90xr7reborn in forum Technical Forum
    Last Post: 08-28-2002, 03:45 PM
