Results 1 to 10 of 10
Thread: Tailshaft seal M5R2 part number?
    Boston, MA
    7,350
    Can anyone tell the part number for the tailshaft seal on a M5R2? I think the Ford ones are the recomended ones so they dont leak. How much are you paying for them?
    Dec 2003
    Altoona IA
    3,237
    I think you'll find your answer here
    http://www.sccoa.com/forums/showthre...highlight=m5r2
    Home of the Whopper
    3,423
    Since I couldn't find Rico's answer in Mike's link...........
    does anyone have a factory part number on the M5R2 tailshaft seal?
    Oct 2004
    Metro Denver Area
    2,514
    I think this is the one
    E8TZ7052C
    7,570
    That's the one, an old F-150 part number ...
    cheers
    Ed
    Home of the Whopper
    3,423
    Great! Thanks guys. Ed, do you know if the number still works?
    7,570
    It's still a valid part number to order ... it fits all of the 4x2 F-150s with the M5R2 trans. Lots of those around to be looked after yet!
    Aug 2004
    Batavia,OH
    2,019
    On rockauto SKF 14900. I find the skf are identical to OEM seals, I try to avoid others.
    It isn't a cheap seal but it is a good one. If you need a bushing or yoke any seal will leak. I have replaced quite a few bushings on these. Usually the yoke is bad at the same time.
    factory number from rockauto is E8TZ7052C
    Alan
    Home of the Whopper
    3,423
    My yoke does have some scoring. Maybe I would be better off just leaving everything as is until the trans needs gone through again. I'm not really looking for more stuff to do
    Aug 2004
    Batavia,OH
    2,019
    The bushing isn't that expensive I want to say it is about $25 but you have to take the extension housing off to change it and the hardest part is you need a yoke. I may be able to buy the yoke directly from sonnax I have never tried. Would be nice to have access to a mill with a boring bar to bore it to the size of a 4r70w yoke. The bushing is thick enough to handle it.
    Alan
  1. I found this FAQ on the SC
  2. Part number for AUTOZON SOLID MOTOR MOUNTS!
    Last Post: 02-02-2005, 01:30 AM
  3. 8.8 Differential Rebuild Kits:
    By Rich Thomson in forum Technical Forum
    Last Post: 06-22-2004, 07:46 AM
  4. Need part number for TV cable brass bushing and cotter pin
    Last Post: 07-18-2002, 12:43 AM
  5. MagnaFlow Resonator...Which part number???
    By cudaz101 in forum Technical Forum
    Last Post: 07-13-2002, 03:42 AM
