Results 1 to 6 of 6
Thread: Rear wheel hub question
    Norcross, GA
    3,326
    I did a search and want to verify if I read correctly. Is there any difference between a '90 rear hub and a '94 rear hub? Are all years indeed the same? My original '90 rear wheel bearings are fairly well worn and I have a set of 94 rear hubs and axles in excellent condition all ready to slide right in. Do the original '90 brake calipers bolt right up? They call for different brake parts between the 2 years so I was confused and wanted to make sure I could just swap out the axle and hub assembly while retaining the original brakes. My pads and rotors are new and I have a new spare set and don't want to waste them.
    Forked River, NJ
    2,092
    It appears that Ford lists a different part number hub for 89-91 and 92+. The knuckle part numbers seem to change also.
    Hopefully Fast Ed will chime in.
    Lakeville, MN
    13,517
    If there is a difference, it is likely the machined lip used to locate the brake rotor. I'm not sure why the knuckle would be different unless it is something to do with the brake caliper mounting.
    7,583
    Rear hubs are the same for all MN-12, disc or drum, 89 - 97. Latest OEM number is F3SZ 1109 A.
    cheers
    Ed N.
    Norcross, GA
    3,326
    I made all sorts of measurements and they were the same. I also found out that the difference in the brake caliper has to do with the rotor thickness and not the mounting so I'll be able to leave all the brake components in place. Thanks for the info.
    7,583
    That's correct, Mike. The 89-92 used thicker rotors, so the pads, calipers, and caliper anchors are different as well between those years and the 93-97. Everything on the brakes can be interchanged as a complete set.
    cheers
    Ed N.
  1. I found this FAQ on the SC
  2. Continued ABS woes (and others)
  3. Rear hub question
    By 91_SC_BIRD in forum Technical Forum
    Last Post: 03-20-2006, 10:34 PM
  4. 92 Rear Hub Wanted
    By 92strokedbird in forum Super Coupe Club of Ontario
    Last Post: 11-10-2003, 07:21 AM
  5. Rear brake question for George D. or DLF
    By Nettlesd in forum Technical Forum
    Last Post: 02-28-2003, 06:34 PM
