Ron,
Is the spring-loaded tensioner itself worn out, or just the idler pulley that bolts to it? If it's just the pulley that's affected, then you can get a replacement from Canadian Tire cheap. Actually, I would recommend you replace all of the tensioner pulleys with Dayco part # 89016. I think they run about $22 each.
Cheers,
Sean
