Results 1 to 11 of 11
Thread: what are these codes?(video)can you help tell me them
    Oct 2006
    48125,michigan
    4,137
    can someone tell me these codes im havin trouble picking them up.
    Oct 2009
    Spokane Wa
    1,209
    hmm i have never seen one beep that slowly.
    the first time I listned i got
    33
    13
    then there is a 3 at the end.
    the second time i listned I thought I got different numbers.
    Oct 2006
    48125,michigan
    4,137
    Quote Originally Posted by 90turbo1 View Post
    33
    13
    yea im kind of confused thanks for helping anyone got an idea? this is my first time dealing with obd1.
    Memphis, TN
    1,911
    Umm, sounds like 111, or no codes detected. You testing an early or late model? Also, how about using the paperclip method of counting the CEL flashes on the dash?
    Jan 2010
    Bossier City, LA
    2,222
    I get 33, a separator code, and a 33. So a temp 33, then a stored 33.
    33 is "EGR Valve Position Sensor" failure.
    I'd bet a good cleaning - or a replacement of - the EGR valve would not be amiss, then a code clear, and then a run to see if it goes away.
    RwP
    Oct 2006
    48125,michigan
    4,137
    RwP
    car is a 92 no egr
    i believe they are
    111 111
    xr7dave is helpin me out.
    Jan 2010
    Bossier City, LA
    2,222
    Huh. Sweetie's '91 has EGR on it.
    111 is another possibility, true. Any "Check Engine" lights inside? If so, then "111" isn't it. If not, then "111" is probably it
    RwP
    Oct 2006
    48125,michigan
    4,137
    RwP
    yea no engine light is on but there is alot more going on then this im sure.
    it wont complete the koer test
    Apr 2003
    North Port FL
    1,386
    Did you get the first set of codes figured out? I'm getting the exact same slow codes.
    Thanks
    Jake
    Mar 2004
    Boise, Id
    529
    I got a cde 111 as well. On my 92 when all is good I get a code 111. Even when I ran out of gas during test doh I need to rerun to make sure. Maybe I'll go do that now.
    Oct 2006
    va beach,va
    2,584
    That is 111 seperator and 111. You have some serious rust issues on that body...huh?
