Well new to the forum hopping to soak in alot of info from here about the m90. i already learned alot within the few days ive been registered. Well enouph about that now about my car.
Sorry not a t-bird
is a 1991 Mitsubishi 3000gt SL
It has a 3.0L engine with 10:1 compression
MY mod list is as fallows
injen intake
Maximal Performance Test Pipe(2.5")
EK2 Down Pipe(2.5")
Made Solid Motor Mounts
ACT 2600 extreme street clutch
ohio short throw shifter
MSD 8.5mm plug wires
Iridium plugs
Solid shifter bushings
eaton m90 (oval inlet) running 5 PSI
walbro 255
360cc injectors
2.5" cat back system
99 lifters
Overdriven crank pulley 4.679"
2.5" SC pulley
About a 64mm TB (stock)
Some other minor ods and ends also
My plans
- incorporate a FMIC into the intake system
- Get a Very big crank pulley with 6 ribs
-get a sc pulley with 6 ribs
-get a new sc housing (square)
-get the GTP rotors and modify them for tbird m90
-Bigger TB maybe 90mm or is there a better option?
-incorporate a bypass valve into my setup
-Port supercharger some
-Another walbro 255 fuel pump
-run e85 fuel
-plan on keeping 2.5" exhaust but will i get any benefits from a 3"??
im not sure what psi i will get because i will need to calculate it all out but im looking for like 14 or so psi
Now how about some pichures lol
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid354.photobucket.com/albums/r439/Cyote1/Summer%20project/VIDEO0004.flv">
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid354.photobucket.com/albums/r439/Cyote1/Summer%20project/BurnoutSC.flv">
I have pictures of me fabricating everything from start to finish its REALY LONG thousands of pictures but if your board one day this is the album i have them all in, there is sub folders in there also
http://s354.photobucket.com/albums/r439/Cyote1/Summer%20project/
let me know what you guys think!!! lots of work/time/money/blood/sweet/tears/fustration into this baby
Sorry not a t-bird
injen intake
EK2 Down Pipe(2.5")
Iridium plugs
walbro 255
360cc injectors
99 lifters
2.5" SC pulley
My plans
-run e85 fuel
