Carl,
I have the following:
motor mounts
struts/shocks
speakers.
I might have a vmm, but I have to double check.
Shoot me an offer on these parts
Thanks
ken
Originally Posted by
Regul8r
I have a 90 and here is a list of parts I NEED for my car!
SOME I need ASAP!
Others... depends on the money and what you have.
ASAP Motor Mounts (driver side is BROKE)
ASAP Lowering springs (looking for 3/4" or 1")
ASAP Strut/shocks all 4 corners
ASAP ARP Head stud kit
ASAP Head Gaskets
ASAP Gasket set or individuals (doing head swap)
ASAP 3" single pipe from Resonator to the rear (need it for the straighter late model tank) I am putting in a 94 Tank
ASAP 255 fuel pump for a 94 Tank
ASAP Rear suspension bushings for complete rebuild (compensators too)94/95 SC M90 (have a possibility on this IF I can find the plenum for it)
94/95 SC M90 Plenum
5-15% pulley system(SC pulley or JS/SC combo)
larger than stock injectors (not needed, just MIGHT do them)
VMM
VMM dash surround
Speakers all the way around
Both Door hinge pins and strikers
94/95 Xenon lower front air dam
I have a line on some of these parts and am buying many of the others offline in the next couple weeks.
Putting this out there to see if anyone has stuff laying around they would like to liquidate for a little cash. Would rather give my money to a fellow SCCoA member than the big companies!
PM me or respond here.
I already have...
Ported Heads on the way
Ported exhaust manifolds
Catalytic Converters
Borla 2-1 Resonator
entire front suspension rebuild parts
4 wheel slotted & drilled rotors and pads
front hubs
rear sway bar links
THANKS
Carl
1992 Thunderbird SC
13.322 @ 102.81
1993 Thunderbird SC 5spd..white
2002 F350 SD Diesel (SC tow vehicle)
