K member help asap
TXrgvBIRD
My k member is bent, does anyone know what k member other than sc birds i can use? i.e Base Lx V8 Cougar Cougar base xr7? and what years thanks i need the info asap please someone is selling me a 93 k member
what year is your car ?? If your car is 93 or newer, it should bolt up fine.
If it is older than 93, the subframe has the motor mount offset by about an inch.
- Dan
did same thing to mine.
1992 got the k frame from a cougar and it worked good.
there will be other things that you will have to mod. there are no holes for the power steering pressure line and cooler lines to bolt to. so you will need to drill a few 1/4 inch holes and use bolts and nuts. other than that they are all the same up to 1993.
have fun changing it..... ha ha ha it was a complete blast to change :rolleyes:
ok thanks for the info man, im glad u told me it will be a blast to change it lol ill nake the best of it ill just try to get an 89 t bird k member to save myself the modification issues.
