Results 1 to 5 of 5
Thread: 180 thermostat
    May 2010
    1
    180 thermostat
    Was wondering if anyone could tell me what I have to do to change the cooling fan temp settings to come on at cooler temp with 180 thermostat?
    Dec 2002
    Salt Lake City
    49
    As far as I know, and i'll probably be corrected as is usually the case on here, you will need to either get a tuner or get an electronic fan controller. EEC tuner or Moates quarterhorse etc. can control the fan settings from the engine computer, or wth a fan controller you will bypass the Constant Control Relay Module (CCRM) - which controls the fan. You can get electronic fan controllers from Summit or Jegs and the like.
    Depending on what your long term goals with your bird are and, obviously, $, will persuade you on if you want to get a tuner for the car or a fan controller. But with a tuner you'll need someone to tune it. I'm trying to decide all this myself and its hard cause in Salt Lake I doubt I'll find a decent tuneraround. Anyway let me know if there's a better way out there
    Apr 2007
    New Orleans, LA
    1,957
    send $35 to either fraser or bob to register the definition file
    then buy binary editor program $80
    then buy a moates jaybird $80 and f3 chip $65
    $260 done
    or buy an f3 chip for $65 send it to someone's house and let them program it for you for $20 and call it done at $85 total
    Dec 2002
    Salt Lake City
    49
    Out-Standing, where do we get the f3 chip, and how is that different than the quarterhorse?
    -thanks
    Apr 2007
    New Orleans, LA
    1,957
    www.moates.net
    the f3 chip is the same thing as an SCT chip, you slap her in and go, it is not a programmer and it is not a data-logger
    the quarterhorse is a programmer and datalogger
    if you intend on modifying the vehicle and tinkering with it then get the quarterhorse, else get the chip and 'set it and forget it'
    its up to you
    if you want to learn how to tune cruise on over to http://www.efidynotuning.com
  1. concerns about 180 thermostat
    By 90turbo1 in forum Technical Forum
    Last Post: 09-08-2010, 04:06 PM
  2. Opnions Please - 180 vs 190 degree thermostat
    By SC Spyder in forum Technical Forum
    Last Post: 04-12-2009, 12:21 PM
  3. 180 degree thermostat? Why?
    By AlanEdwards in forum Technical Forum
    Last Post: 06-15-2005, 08:48 PM
  4. 180 thermostat yes no?
    By purpleshadow25 in forum Technical Forum
    Last Post: 07-10-2002, 09:07 AM
