David Neibert
SCCoA Admin
David,
very nice.....isn't that the same setup Gary had on his car years ago? Do you know why the car is running lean on the top end? I thought you had 80lb injectors.
Ken
Ken,
This kit has almost nothing in common with Gary's except they both used a 2.3 whipple. Yes it does have 80# injectors with base pressure lowered from 55 to 40 psi, but the short answer for why it was going lean was because it still has a single 255 lph fuel pump and we were seeing how far we could go without adding voltage from the KB boost-a-pump. With voltage increased we went pig rich on the top end and had to lean it out. Will be adding the dual pumps in the near future, so I don't have to rely on the boost a pump.
