Page 1 of 19 1234511 ... LastLast
Results 1 to 15 of 276
Thread: I need FUEL!!!!!
    Boston, MA
    7,356
    I need FUEL!!!!!
    So there has been little developments or "rummors on the internets"-Bush. About a fuel pressure solution for those that reached the limits. I noticed Boost a Pumps have been used here. But some suggest that they are a good way of straining the and killing the fuel pump.
    MSD some time ago put out a Fuel Pump Booster that was boost refereced. I wonder what some think of this device and if I should just go for it as the Shootout is fast approaching and dropping gas tanks and upgrading other things is getting to be less practical for me.
    http://www.jegs.com/InstallationInst...1/121-2350.pdf
    MSD 2350 Fuel pump booster.
    Anytime you add a turbocharger or super charger to your engine and increase the amount of intake air, there is also a need for additional fuel. This fuel pump booster from MSD is the economical and easy way to meet these increased fuel demands. The booster supplies additional voltage to the electric fuel pump in relation to the increase in manifold boost pressure. The amount of voltage is adjustable within a range of 1.5 to a maximum of 22 volts.
    Not for use with large draw race only fuel pumps.
    Will not work on Pulse Width Modulated EFI systems. (no return line)
    They go for about $300 little pricy but I wonder if its worth the money because it has the boost ref feature and will not be hard on the pump when not under boost.
    Jan 2003
    Woodbridge, VA
    5,145
    A kenne bell BAP can be boost triggered too.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Boston, MA
    7,356
    Is it an accesory or does it come standard. I see it has a wire for a HOBBS switch. Im I incorrect?
    20,948
    It comes standard, but I didn't install the pressure switch because that just adds another varible for tuning. Mine has the wires connected to simulate a closed pressure switch (voltage boost always on).
    Boston, MA
    7,356
    So it it progressive or just an on/off? David why would you tune it? The pressure is dictated by the regulator isnt? I am just trying to achieve no loss of pressure on my system at WOT, Including the nitrous......
    I am hoping no major tuning to be made, only the upper rpms WOT tuning where my fuel pressure drops now.
    Then if thats the case I can maintain my current drivabilitly since its spot on now for the most part, all with the same 51-52#~base pressure.
    If I am reading the MSD correctly it is boost progressive, But i could be incorrect.
    NYC
    17,431
    You guys have been running yoru boost a pumps full blast without boost reference?
    Jan 2003
    Woodbridge, VA
    5,145
    The BAP is just on off with the hobbs switch. If you connect the 2 wires together its on all the time. On the marauders we run it all the time before the fuel pump driver module so the computer has the voltage there if it needs it. Never had a problem with the BAP running it all the time. The voltage is variable thru a knob so you don't have to send max volts to the pump all the time.
    ~Chris
    SCCoA Member #1826
    Boston, MA
    7,356
    I picked up a Boost a Pump from ebay we will see if it works. Although I am other issues with the car. The car is developing a stumble of sorts. Maybe the pump will die to force me to change it to a new one. But I dont see a pressure drop on the gauge when it happens so maybe its spark related, but I dont know.
    I got other issues and things to take car of. The SC shuffle is back in town.
    Chris did you get yours installed? I take it you only need it when you activate the nitrous.
    I also read from other SC applications that the HOBBs switch does not work well since the boost comes on very sudden and creates issues with tuning and stuff. So i think i will run it straight up.....
    Now about volting up the pump, how does it affect pump durability, if the pressure is the same and back pressure is the same as before. Isnt it the back pressure that puts a larger strain on any fluid pump or airpump?
    20,948
    I have mine set to provide 20% extra voltage all the time.
    Dec 2009
    Toronto
    2,102
    Rico,
    Your not starting to work the program so nobody see's you coming hard are you.
    I'm thinking the SC Shuffle is your way of getting your partner to dance a little closer.
    Paul
    Dec 2009
    Toronto
    2,102
    Sorry, reread-It came out a little "pornie".
    Jul 2003
    Ottawa, Ohio
    5,401
    Did you make sure all your lines are not kinked and the fuel filter is good, or possibly just up sizing the lines to -8 feed and -6 return?
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
    Boston, MA
    7,356
    No worries, I am on limited time so it kinda stinks for me. Making plans for the shootout have always been half Azzed. I dont like mystery diagnosis or things that happens sporadically sp. Its hard to diagnose. I got a list of things but I only want to get the important things done. Using this car more then just on weekends have proved to be a big FAIL. So I got to fix the rear end, Get a new set of front tires, Kmember busings, And again ALign Which goes pretty bad with this car. But The stumble is a big problem, I guess Dammon just needed company in the broken SC department.
    Boston, MA
    7,356
    Ofcourse I did not check the fuel filter. I do things backwards. But there not that much miles on the filter the car has.
    Can the pump be failing and not show up on the gauge?
    Nov 2005
    Oregon 97220
    1,018
  1. Got more power, still need more fuel
    By Mike8675309 in forum Non Technical Forum
    Last Post: 07-15-2010, 09:51 PM
  2. Fuel Pump or Fuel Pump Relay and Location?
    By AL-X89SC in forum Technical Forum
    Last Post: 04-17-2006, 12:26 AM
  3. no fuel pressure, have some questions
    By mint91sc in forum Technical Forum
    Last Post: 03-14-2006, 02:38 PM
