Thread: Corner Lights Won't Turn Off
    Louisville, KY
    40
    While walking past my 90, auto, SC, I noticed the locks were up. Using the key fob, I tried to lock them and found tha the battery was dead. I jump started the SC and found that that the parking lights were on. I checked the switch and in was turned off.
    After shutting down the car the lights remained on. I tried to use the alarm button to see if it would cycle off the lights but it didn't work. I ended up disconnecting the battery.
    Any ideas?
    I am thinking that it may be alarm related. I read that the alarm can be dosconnected somewhere in the trunk. Any particular connection?
    Aug 2002
    Jersey Shore, PA
    1,875
    Does it have auto lights?
    Louisville, KY
    40
    Thx for the reply. No autolights on this one. But there is good news.
    When it started acting up, I disconnected the battery (ground) after parking it. Yesterday I went back out to the car and reconnected the battery cable. When the cable first touched, the lights came on, but as I continued replace the cable, the power flashed on/off several times. Ater the third or fourth cycle, the lights stayed off. So for the moment all is well.
  1. No ABS motor, turn signals, vmm, or climate control????
    Last Post: 02-28-2007, 10:34 PM
  2. Rear Corner Lights and Fog Lights 1990 SC
    By Thomas A in forum Parts for Sale
    Last Post: 07-07-2005, 10:49 PM
  3. Replies: 2
    Last Post: 06-30-2005, 11:38 PM
  4. Front Corner Lights 1994 SC
    By TurboPS in forum Parts for Sale
    Last Post: 06-30-2005, 08:47 PM
  5. clear corner lights
    By 90scoupe in forum Technical Forum
    Last Post: 05-30-2003, 10:08 PM
