has anyone removed the quarter window trim? is there clips? or is it glued on?
9 90'silversc Registered User Aug 7, 2010 #1 has anyone removed the quarter window trim? is there clips? or is it glued on?
X XR7-4.6 Registered User Aug 7, 2010 #2 Its part of the quarter window, its bolted on from the inside.
txsc Registered User Aug 7, 2010 #3 Remove the rear seat and interior quarter trim panels. Then you'll see the nuts that you must remove to pull the glass/moulding assembly. Totally worth the effort, in my opinion. JD
the-big-e Registered User Aug 8, 2010 #4 Be careful removing them.... The black sealant that Ford used will get all over everything.....
Payton Registered User Aug 8, 2010 #5 the-big-e said: Be careful removing them.... The black sealant that Ford used will get all over everything..... Click to expand... Sooo true)))
