Results 1 to 13 of 13
Thread: 4.5 liter V-6
    Jul 2010
    279
    4.5 liter V-6
    Has anyone tried to put the 4.5 SVO V-6 (based on the 3.8) into an SC? It can be bored and stroked to 312 c.i.d. Part No: M-6010-E380. I have no idea whether it will bolt up same as the 3.8, but the info I have says it retained the production clutch housing bolt pattern for use with ford manual transmissions. Also had available aluminum "high-port" cylinder heads. Part No: M-6049-F380. For the V-6 purest it seems like a major upgrade.
    Aug 2002
    3,660
    Currently being done over at V6power.net, in a fox body.
    http://www.v6power.net/vb/showthread.php?t=45627
    Jul 2010
    279
    Fascinating
    I assume they are rather rare. Thats a shame, I'd like to have one. I'm looking at a 1990 performance equipment catalog from Ford SVO. They were designed for the NASCAR circuit and all about performance.
    Aug 2002
    3,660
    Jul 2010
    279
    So, will it fit right in, motormounts, block length, etc?
    NYC
    17,431
    You can make anything fit.......
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Quote Originally Posted by PDQ SC View Post
    I think the block length is slightly larger because of the larger bore spacing. But probably close enough to fit. I have no idea how the mounting configuration compares.
    God bless!!!
    Former Birds:
    Apr 2003
    Ventura, CA
    1,795
    How high is the deck height on those blocks compared to the 3.8? Would it fit under the stock hood? Would an SC intake even fit--and if so, would it choke the motor so badly as to make using it pointless?
    Jul 2003
    4,993
    Looks like the heads are much, much taller to allow the intake ports to be much straighter. That means the intake is wider and higher up. Check out the picture. Look how thick the head decks are! LOL.
    http://www.v6power.net/vb/attachment...8&d=1274570469
    God bless!!!
    Former Birds:
    Sep 2004
    Indy
    5,623
    The stock intake definitely wouldn't fit.
    1994 SC
    4.5L Twin Turbo SVO
    Project GTFD
    Jan 2009
    south florida
    399
    you should really check out some of the threads over on v6 power. but anyways, the motor mounts are the same..this 4.5l block will drop right in. bellhousing bolt pattern is the same. timing chain cover is IDENTICAL, water pump is the same. accessory brackets can bolt on just like a 3.8 motor.
    there have been 3 people to swap a 3.8 for a 4.5l and have it run. snoopstang was one, Tom Y was another, and...ahh, I cant remember the guys name, he's over on V6P but he's got a 4.5l swap. wait, there was an 8 second v6 tube chassis tbird that had a 4.5l svo motor. there may be more people, but those are the only ones that are the most popular.
    Apr 2003
    Ventura, CA
    1,795
    Requires signing up to view.
    Jul 2003
    4,993
    Quote Originally Posted by Mercutio View Post
    Gotcha ... forgot about that rule. I rehosted the pic for you (temporary).
    God bless!!!
    Former Birds:
  1. 4.5 SVO motor I had built
    By Nettlesd in forum Non Technical Forum
    Last Post: 03-31-2007, 11:57 PM
  2. Fords 6 liter Modular v8
    By XxSlowpokexX in forum Non Technical Forum
    Last Post: 10-25-2006, 09:00 PM
  3. changing bolt pattern to 4.5
    By amcagreg in forum Technical Forum
    Last Post: 03-16-2004, 12:06 PM
  4. 4.5 Svo Motor
    By Randy N Connie in forum Non Technical Forum
    Last Post: 05-28-2003, 01:57 AM
