Results 1 to 4 of 4
Thread: procedure for gear oil change 5 speed
    Aug 2004
    Panama city
    447
    quickest easiest way to change out gear oil in the transfer case of a 91 5 speed??and what lube to replace with?
    Dallas, TX
    5,755
    Raise the car up on both ends so that you have room to get underneath. Front end just a slight bit higher than the rear. Like 1" or so. There is a drain plug at the bottom rear of the trans. Take it out and drain the old fluid. Put the drain plug back in w/o over tightening. The fill plug is about mid ways up on the same side. Remove it and... use a funnel and tube to pour new fluid in.
    The m5r2 came from the factory with mercron fluid. You can use that and add 2 oz of friction modifier, or, as I did, use the pennzoil synchromesh fluid with a few oz of friction mod. However, I have the carbon fiber lined synchros, so the combination of fluid +FM has a different effect.
    Feb 2003
    Murrysville, PA
    1,276
    I couldn't fit a funnel in when I did mine. I actually cut a garden hose and plugged it into the fill hole, routed it up towards the shock tower and filled from there.
    -Tesla Model 3 Performance-
    -89 White 5-speed, 450HP 430TQ-
    My garage
    Dallas, TX
    5,755
    I mentioned a funnel and tube, but on second thought I think since I used the pennzoil bottles with the pointed tip, I slipped a rubber hose over the tip and and I was able to squeeze the fluid in by holding the bottle up higher than the opening.
  1. Just a quick exhaust question
    By birdofprey in forum Technical Forum
    Last Post: 03-20-2005, 10:06 AM
  2. Quick Power Steering Question...
    By SteveSilverSC in forum Technical Forum
    Last Post: 05-26-2004, 11:57 AM
  3. Quick Blower Question
    By Melon in forum Non Technical Forum
    Last Post: 04-07-2004, 10:13 PM
  4. Quick question about ignition switch....
    By LJGriggs in forum Technical Forum
    Last Post: 12-23-2003, 10:49 AM
