Quik95SC
That too.....
got any way to log it to see what is going on??? Didnt know if you got to put it on the dyno or not. QUOTE]
Working on getting the 1/4 horse and asociated stuff by the time I get to your place.
Dyno only showed I had a bad miss above 4000 rpms, never an initial stumble cause I was already going over 55 mph when jeff nailed the gas and it started to miss in the higher RPM's
I never get into the alcohol injection during the burnout, actually it never goes into boost during the burnout, so no I don't think that is the issue. besides I did try clearing it out after the burnout on one of the runs, and it made no difference at all.
I know it is long overdue to get my own stuff to tune and make adjustments myself, so that is what i am working on. I just need to know exactly what I need to purchase to make it happen. I know I will be going with the quarterhorse for monitoring the ecu and such, but need to get accessories to monitor boost and AFR as well, those are what I am a little confused about getting and how it all ties together, so I can see it/monitor it on the dashboard.
I understand the Quarterhorse sees whats going on in the ECU, but boost and AFR are not in the ecu to monitor as far as I understand, so what other items are needed to log those parameters and tie them all into the laptop to log and make changes with?
The computer part doesn't bother me I work on comouters all day for a living so that part I am confortable with, just the inital hook-ups and what i will need to do it right the first time around.
Smitty
