Results 1 to 15 of 30
Thread: what are the best first bang-for-the-buck mods?
    Nov 2006
    Wausau, WI
    146
    i've had the SC swap done in my mustang for quite some time now, have an 8.8" rear end w/ 3.73s, and recently did a 5-speed swap. now it is time to get a little more power and am wondering what you guys do for your first mods. right now i have a pretty much bone stock 89-93 setup.
    please answer my three questions...
    If you had $500 to spend on performance mods, what would you buy?
    If you had $750 to spend on performance mods, what would you buy?
    If you had $1000 to spend on performance mods, what would you buy?
    NYC
    17,432
    Im assuming you did exhaust and perhaps a larger fuel pump.
    The next line of mods I things I would go for are:
    1) S ported 94/95 blower
    2) MP inlet
    3) 5% jackshaft pulley
    4) Methanol injection kit
    5) A Dyno tune
    If you have extra funds I'd upgrade to a larger 42lb injectors 75-85MM TB, 3.5 intake tube, 90mm LMAF with the above. Pricing will depend on what you get these parts for. You can find many used and you would be pushing that $1000 mark
    If you want to go cheaper you can just find yourself a 94-95 blower which is a great upgrade from the earlier model ones even unported.
    Whatever you deciede to do a good tune will be key afterwards
    Aug 2002
    Rock Hill, SC
    842
    Quote Originally Posted by slow_v6_stang View Post
    I didn't hear you mention what kind of exhaust you had. Like our SC's, that would be my first stop, a very nice true dual exhaust. Seeing as you have a Mustang (89-93), this should be very readily available in the aftermarket, more so than our SC's. That is probably what I would do with $500.00. You could also do other mods, like cold air intake and high flow air filter in that $500.00. How about some pics of your car and the engine bay?
    Madison, Ohio
    17,684
    My experience with the Mustangs is that the stock IC is extremely ineffective so I'd start with a FMIC. That should cost less than $500 but it won't get you more power on the dyno, but it will make more power on the street.
    Then you can get a set of UD's and a 10% blower pulley although that blower won't like the OD. However, you can't run a better blower without more injectors so the next step is going to cost you a few bucks. You'll need injectors, MAF, chip, and blower all at the same time. But that will net you big gains.
    There are always a million ways to approach the situation though.
    Email me here.
    Nov 2006
    Wausau, WI
    146
    Quote Originally Posted by XxSlowpokexX View Post
    2) MP inlet
    5) A Dyno tune
    yes, i have 2.25" true duals with flowmaster 40's and the SVT focus 310lph fuel pump. what does the "s ported" mean?
    Quote Originally Posted by phils89sc View Post
    my mustang is a 1998 w/ the 89-93 SC setup, and i have duals (see above). i posted some pics below. i have kind of a cold air intake, just missing the tube between the MAF and throttle body.
    thanks for all of the input, looks like i have a starting point now, however more opinions are appreciated. i do have some decently high intake temps, so i think a FMIC would be nice (or at least a super coupe radiator) here are some pictures of the car.
    21,125
    I would do.....an SC aluminum radiator (or generic one with same width), a double intercooler with fan, 5% OD JS pulley and a set of underdrive pulleys.
    Aug 2002
    Rock Hill, SC
    842
    Dude, that is sweet....I wanna do something like that...What computer are you using? How was the wiring for the engine harness, etc..? Would you PM me a writeup on how you did this? thanks. -Phil
    Jan 2009
    West Georgia
    286
    You have the mustang radiator in, might as well do a FMIC, the pipe is cheap and the intercooler is like 78 shipped. Fits right in there nicely. Some have cut the lower bumper section out, but I just left it in. You can see how much is exposed.
    Once that is done you can overdrive it to get a little more out of that blower. You need to read the performance section to get a good idea on how some mods are better than others.
    Justin
    89 Silver 5 Speed, 234K bone stock (for now)
    94 Mustang 5 Speed, Anni powered with a FMIC...
    Nov 2006
    Wausau, WI
    146
    v6sprout's write-up -
    http://v6power.net/vb/showthread.php?t=5716
    my write-up -
    http://sn95forums.com/index.php/topi...html#msg293891
    between these two links, you shouldnt have many questions about the swap.
    NYC
    17,432
    An S port blower is a ported 94-95 type SC blower from Magnusun. You can however get a stock 94-95 SC blower and have that same port done. Look for photos of it on teh SCCOA. I'd do that over OD'ing your factory 89-93 m90 anyday. Just swapping in that blower is a noticable difference. Your radiator is currently blocking cool air to your IC...So getting an SC type radiator will allow you to at least build a shroud to get cool air to it.....Of if you run a front mount you may have room for a nice full size rad.
    BUT AGAIN...If you just find yourself a 94-95 blower. You can bolt that on as is and get a noticible difference you can feel even unported. To me thats operhaps the best bang for the buck
    Madison, Ohio
    17,684
    Damon, you are overlooking the fact that he will be out of injectors with any blower upgrade. You can get away with stock injectors on an 89 blower but not on a 94+, well at least if you don't want to be hitting 100% duty cycle at about 4800rpm.
    On my car with an MPII and 10% OD on an otherwise stock motor I'm running 75% duty cycle on 50's. That would be 125% duty cycle on 30's.
    By looking at his pictures you can see how retarded the IC installation is on a Mustang. Even if he gets an SC radiator there won't be any pressure differential across the IC so it won't work worth a damn and a double IC will be worse. Been there done that. Get a FMIC first and go from there.
    Email me here.
    Oct 2004
    Charlotte, NC
    8,159
    Definitely a FMIC will need to be installed for optimal performance....
    Bigger injectors with a higher capacity fuel delivery system...
    Ported heads with bigger valves....
    NYC
    17,432
    Dave..Thats why I said hed have to build a shroud for the IC if he went that route. Personally Id say a full size rad and a front mount if he can.
    As far as upgrading to just a 94-95 blower I cant imagine that using more injector then OD an early model blower 10% or even 5.
    Aug 2002
    Rock Hill, SC
    842
    Do you have or can make any audio / video clips of your exhaust sound? Maybe something while behind the car and revving or while driving?
    Madison, Ohio
    17,684
    I've dyno tested the theories. The overdriven early model will be about the same as a stock late model until 4500rpm where the early model starts to crap out and the late model keeps going. This is where you run out of injectors.
    Anyway, trust me, the stock IC is terrible on the Mustang due to how far back it sits. When you can build a FMIC for $300, it doesn't make sense to waste time on the stocker or a double.
    Email me here.
  1. Best BANG for the buck? ...opinions wanted
    By joshbea6 in forum Polls Forum
    Last Post: 03-26-2013, 01:48 PM
  2. what to do next /most bang outa my buck
    By shawpdx1 in forum Technical Forum
    Last Post: 08-03-2006, 10:03 PM
  3. Biggest bang for the buck mod i should do next?
    By Jayls5 in forum Technical Forum
    Last Post: 10-17-2004, 10:57 PM
  4. bang for the buck? 95 blower ?
    By lowflying90 in forum Technical Forum
    Last Post: 03-11-2003, 01:05 PM
