Results 1 to 10 of 10
Thread: fuel sender resistance
    May 2010
    72
    what is the resistance for the stock fuel level sender for full and empty? i want to make sure my sender is good
    May 2010
    72
    anyone? no one knows the correct resistance?
    Jan 2003
    Woodbridge, VA
    5,262
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Jan 2003
    Woodbridge, VA
    5,262
    Actually its 15 empty 160 full
    ~Chris
    SCCoA Member #1826
    May 2010
    72
    thanks my sender is bad then. i just checked the resistsnce and its 13.1. so i wonder if i measure the resistance at empty and add a resistor to bump it up to the correct empty resistance for a quick fix. and then take a resistor for full to calibrate the gauge.
    Jan 2003
    Woodbridge, VA
    5,262
    Wouldn't work like that. It is a grid of sorts with an arm that slides up and down. The more pieces of grid it goes across the more resistance there is.
    ~Chris
    SCCoA Member #1826
    May 2010
    72
    Quote Originally Posted by BLOWN38 View Post
    so i dont see why i cant put a resistor(like 5 ohms or whatever it takes to move my resistance of the sender up to 15ohms) on the yellow wire between the sender and the gauge. i know a bit of electrical work. the resister put in series would just add resistance to the circuit to get it to the stock range
    Jan 2003
    Woodbridge, VA
    5,262
    You could add a resistor to the yellow wire to up the resistance of the whole range, but you couldn't add a resistor for full also.
    What exactly is wrong with your gauge?
    ~Chris
    SCCoA Member #1826
    May 2010
    72
    YES thats what im taking about. i dont want to add a resistor for full. i just need somthhing to bump the range up. but what i was saying instead of using a full tank to calibrate the gauge ill just take a 160ohm resistor to calibrate the gauge.
    i never know how much gas is in the car. ive been driving for the past 2 days with the low fuel light and check gauge light on. >.< ive ran out of gas one too many times and it sucks.
    May 2010
    72
    ok so im about 13ohms at empty and i put 13 gal in and i got 47.2ohms. so i did a little math and its about 70ohms full. so the thing is done but imma calibrate my gauge anyway to 70ohms full to read correctly.
  1. Wtb! Fuel level sender only for 1992 gas tank
    By 90turbo1 in forum Want to Buy
    Last Post: 02-09-2010, 01:27 PM
  2. Fuel Delivery
    By Magnum Powers in forum Technical Forum
    Last Post: 08-04-2008, 04:32 PM
  3. Fuel Problem-Code 95
    By Mikko in forum Technical Forum
    Last Post: 04-26-2008, 07:12 PM
  4. The Reality of Top Fuel Drag Racing
    By joshbea6 in forum Racing/Track Results
    Last Post: 03-22-2008, 02:28 AM
  5. Fuel, timing, or balancer?
    By SlinginBeauty in forum Technical Forum
    Last Post: 01-22-2004, 11:47 AM
