Results 1 to 15 of 29
Thread: Turn signal issue.
    Feb 2009
    Mount Vernon, WA
    318
    Turn signal issue.
    Hello, I've tried the seach in this forum, but it will only search turn, and signal separately. Which only comes up with a billion threads to no where. So, can anybody tell me why the turn signal will work fine sometimes, sometimes not at all, sometimes sporadicaly. Any ideas would be great. Thanks,Shawn.
    May 2010
    Oregon
    144
    Your SC has fog lights right? Does it have auto dim? It is the multifunction switch. It is that whole assy with your wipers, low/high beam, hazards and turn signals. It was a TSB or recall on most our cars. Make sure the pigtail isn't melted when you change it. If it is put a new one on. Buy Wells, duralast or OEM. If you buy from AM or partstrain you will get bad ones. I know I put two bad brand new ones in before I bought a decent one.
    Oct 2006
    va beach,va
    2,585
    Quote Originally Posted by EatonEmployee View Post
    And also check the ignition switch on the column. They come apart and can cause intermittent turn signal malfunction....12.00 part...
    Feb 2009
    Mount Vernon, WA
    318
    Standard headlight switch, new and good, newer good headlight harness, foglights are not working. But have not tried them since headlight/dashlight fix. Put in a used junkyard multifunction switch that actually clicks when you hit it. I know, its a used part too... The harness' looked good when I switched it. ? Thanks
    Feb 2009
    Mount Vernon, WA
    318
    Hmm
    I will try that first since it's cheap and easy. thanks.
    Quote Originally Posted by frdlvr30 View Post
    May 2010
    Oregon
    144
    hold up, you swapped all three at once. I always swap 1 part at a time so if I have a problem I can troubleshoot it. Now you have no foglights and you could have three culprits. Most likely your standard headlight switch was not for a car with foglights. Correct me if I'm wrong folks.
    Feb 2009
    Mount Vernon, WA
    318
    Sorry for the confusion.
    I first changed the burnt headlight harness and turnsignal stalk. Then I tried a different headlight switch. Since the new headlight switch didn't cure the dashlights I put the motorcraft one back in, and the one i bought in the glovebox. The dashlight culprit was the po's hack job on the stereo wiring. So now the lights work great but the turnsignal is still intermittant. It seems to happen mostly with the headlights on. ? As for the fog lights they did not work when I bought the car and still don't. I have not messed with them yet. Was hoping headlight switch would get them working. Going to check for voltage, but not a high priority yet. Does this help? Thanks for the imput.
    Oct 2004
    Charlotte, NC
    8,159
    How did you fix the PO's hack job on the wiring harness.....
    Are you sure you installed the correct MFS.....
    There are 3 different MFS...
    English, IN
    4,513
    I'd definately check the ignition switch. They ALL will wear out after awhile. Don't put it off either. If you have an 89-91?, you could lose your brakes!!
    I lost turn signals the other on my car...everything else worked fine (I have a conventional brake swap). Turnsignals worked the next day....the following day, the car wouldn't start. I'm sure the ignition switch is the problem...it was looking a little loose when I had the dash apart, but I was trying to get my car finished for the shootout.
    On another SC, I lost turnsignals and brakes at the same time...on an exit ramp!!! Changing the ignition switch fixed it.
    Ed - what are the three different MFS's? I only knew of two.
    Matt Haub
    Shootouts: '09 SS 1st | '10 Mod1 2nd | '11 Bracket 3rd | '12 Bracket 1st | 2013 | '14 Bracket 3rd | 2015 | '16 Bracket 1st & Mod2 2nd | '17 Spectator | '18 Freeze-Plug Champ
    Black '89 5spd - 281K miles, MPx, Alky-Inj 387rwhp, 438rwtq (new motor) Best 1/4mi:12.521, MPH:107.23mph (old motor)
    Feb 2009
    Mount Vernon, WA
    318
    Wiring harness for headlights, I cut the burnt one out and spliced in a good one. For the stereo I found a couple of wires under the plastic touching metal with no insulation or spotty tape job. Deck looks to have been cut out. So I covered all open wires and bundled them nicely till I get a deck. As for the MFS? It looked the same as mine and had all the same pins in the same locations. And the turn signals do the same intermitant no work thing. This morning driving home with the lights on The signals worked fine. Yesterday eve only once in awhile. I have a new ignition switch, just need to get torx bit.
    Quote Originally Posted by the-big-e View Post
    Feb 2009
    Mount Vernon, WA
    318
    Ignition switch??
    Well, I put a new BWD ignition switch in and the signals wouldn't work at all? Also It died and would turn over fast, faster than normal but would die as soon as you let off the key. Put the ford switch back in and fired up worked fine. Anyone had issues with oreilly's BWD brand stuff before? That is the third suspect Item I've got for this car, headlight switch,dis module, and ignition switch. In all situations I put the ford part back in.
    Mar 2009
    Tacoma, WA
    558
    I don't know if you checked this in regards to your turn signals, but my relay had a bad solder joint that just went out, and all I did was resolder it and they started working again. My turn signals would do the same thing yours were doing.
    Oct 2004
    Charlotte, NC
    8,159
    There are white letters on the bottom of the MFS that end with AAD, BAD, and CAD.....
    AFAIK, they are not interchangeable....
    Feb 2009
    Mount Vernon, WA
    318
    relay?
    Where is that relay located? Thanks, Shawn.
    Quote Originally Posted by sts70004 View Post
    Mar 2009
    Tacoma, WA
    558
    Quote Originally Posted by sc91gt View Post
    Its under the dash board, on the driver's side, toward center console. Its a large black relay. Biggest one in there, and its mounted on the flat part under the dash, not on the vertical part under the dash thats on the transmission tunnel.
  1. turn signal issue?
    By 92sclikenew in forum Non Technical Forum
    Last Post: 12-13-2009, 05:39 AM
  2. 1990 Driver's Side FRONT Turn Signal
    By TexBear in forum Want to Buy
    Last Post: 08-02-2009, 10:50 AM
  3. Driver's side turn signal lens
    By TornAndFrayed12 in forum Want to Buy
    Last Post: 08-23-2005, 08:08 PM
  4. WTB turn signal switch
    By ben04 in forum Parts for Sale
    Last Post: 08-16-2005, 05:39 PM
  5. Turn Signal Problem
    By carlislesc in forum Technical Forum
    Last Post: 04-22-2004, 10:06 AM
