Results 1 to 11 of 11
Thread: is this normal?
    Mar 2006
    San Jose, Ca
    1,806
    Question is this normal?
    so tonight i pulled into my friends driveway and he has a deep gutter...I rolled into the gutter and my rear driver wheel was off the ground and I got stuck because the wheel that was off the ground was spinning and the other wheel was doing nothing...
    is that normal? isnt the diff supposed to switch power to the other wheel?
    it has the stock diff with about 115k mi on it...i havent installed my auburn pro yet
    Aug 2009
    from miami now in augusta ga
    635
    u should of took a pic of that !!!!
    Mar 2006
    San Jose, Ca
    1,806
    it was dark but it wasnt balancing on frame or anything just that wheel was off the ground...but I thought the drive wheel was the passenger side?
    reguardless both wheels should have gotten me up the driveway right?
    Nov 2008
    Corvallis, OR
    95
    lol, I've done that exact same thing. Do you have a limited slip diff?
    Mar 2006
    San Jose, Ca
    1,806
    I thought so it is the stock diff that came factory...I cant wait to get my auburn pro in
    Oct 2007
    Ohio
    113
    meh just take off the rear cover and weld the spyder gears that will fix it
    jk
    May 2003
    Robinson, Pennsylvania
    1,122
    the sc does have limited slip but when 1 wheel is off the ground there isnt enough pressure to lock the clutches to the other wheel
    Mar 2006
    San Jose, Ca
    1,806
    that makes sense...and when both are off the ground they will both spin...
    I still thought the passenger side was the drive wheel cause that side on my car has the fat shaft
    21,172
    Quote Originally Posted by 91BLOWNBIRD View Post
    Fat shaft is not for added strength, the additional mass is intended to create a differnt harmonic frequency than the driver's side to reduce wheel hop.
    Mar 2006
    San Jose, Ca
    1,806
    oh ok interesting
    Oct 2010
    199
    I don't know about any of the other years of SC's, but my 89 was the same way. One tire off the ground and the other would spin, even though on a hard lunch on flat ground both tires would smoke.
  1. What's normal driving coolant temperature?
    By Payton in forum Technical Forum
    Last Post: 06-06-2010, 11:19 PM
  2. Normal Temp Gauge Reading?
    By kbuhagiar in forum Technical Forum
    Last Post: 01-04-2005, 12:36 AM
  3. Replies: 16
    Last Post: 12-11-2002, 04:00 PM
