Results 1 to 8 of 8
Thread: Help diagnosing wheel bearing noise
    Oct 2009
    Spokane Wa
    1,209
    so not a SC but its a 1999 F-150 4x4 extended cab. 5.4 transfer case on floor. ect ect.
    its got a bad wheel bearing noise and I cant rember what the old rule of thumb is.
    if I drive straight and hit 35 and above the noise is there low pitched rumbleing noise. i cannot tell in interior what side it is.
    if I turn to the right the noise remains constant (above the 35mph threshold)
    but if I turn left (like on a freeway onramp) noise goes away completely.
    what do you guys think.
    thanks
    Sep 2006
    New Braunfels,Texas
    578
    The left side...noise will be more prevalent when under load
    Oct 2009
    Spokane Wa
    1,209
    yeah ok, thats the conventional thinking i hear from everyone. but... about a month ago I replaced that wheel bearing on the left side and I rember the noise didnt change one bit after i installed that bearing.
    what are some other possibilitys that could make a wheel bearing type noise that goes away turning left?
    i need to get under truck and hook up my chassis ears to the truck and drive it I guess. just cant find time and I dont wana shot gun 180 dollar wheel bearings at it.
    Sep 2006
    New Braunfels,Texas
    578
    Just trying to help............
    Apr 2005
    Western New York
    485
    well if you can get any play in the wheels when jacked up thats usually a sign of a worn wheel bearing. My sc and subaru after some odd noises showed up this way.
    Oct 2009
    Spokane Wa
    1,209
    Quote Originally Posted by ecyrbh View Post
    no I know, thats why it is baffling to me also, now I dont count out the fact that I may have gotten a bad replacement bearing but i would think the noise would change some from bearing to bearing.
    I was told that maybee my spider gears in the front diff may cause this noise, as the drive axles turn with the wheels constantly, but are disconected by the vacuum solenoid on the diff.
    is this a possiblilty, there is no metal in front diff fluid. (changed with new bearing)
    Apr 2004
    48183
    3,934
    raise vehicle up on all 4 jackstands...
    get someone in the truck and put it in 4 wheel high and put the truck in drive
    as the wheels are turning have someone LIGHTLY push on the gas pedal to about 2000 rpms or 25-30 mph
    with the wheels spinning grab the coil spring you will feel a grinding or vibration in the spring itself that will be more noticable on the bad side
    but rule of thumb if the noise is there going straight and you turn left and it goes away then it is the left bearing, as if you turn right and it goes away then its the right one because you are removing the load from that bearing
    Oct 2009
    Spokane Wa
    1,209
    FIXED!!!
    It was the pass front wheel bearing, replaced it and noise is gone and car is smooth as a babys rear end... ha ha
    what I dont understand is that if the pass side is the faulty one, why did the noise go away when turning left and putting load on that bearing.... contrary to all suggestions from most people.
  1. Timken Wheel bearing help
    By Micahdogg in forum Technical Forum
    Last Post: 04-16-2010, 10:44 AM
  2. Wheel Hub Bearing
    By Darkwhite in forum Super Coupe Club of Ontario
    Last Post: 06-15-2007, 10:00 PM
  3. Super Charger Bearing noise
    By uwillbow2me in forum Technical Forum
    Last Post: 05-11-2007, 11:58 PM
  4. Help PLEASE ??? Newbie with bad rear wheel bearing
    By AZ_Johnny in forum Technical Forum
    Last Post: 10-03-2006, 10:06 AM
