Results 1 to 15 of 24
Thread: Testing for Vacuum Leaks
    East Hartford, CT
    3,498
    I want to spend so time trying to determine if there are any vacuum leaks on the car.
    Is it possible to pressurize the entire intake, blower, IC, manifold, exhaust systems. Something like making up an adapter with a shrader valve and install in on the MAF then block of the tail pipes and put 40 or so pounds of air pressure on the entire system.
    If anything I would think the header ball flanges would be leaky as hell but everything else should be tight.
    Is there any chance something like this could work???
    HOW THE HECK DID I PUT THIS IN THIS FORUM>>>>>DANG IT!!!!!!!
    Brian Oatway
    '94 SC 2.6KB C4 Auto
    9.956 @ 135.12 mph 1.364 60'
    525rwhp/460rwtq
    "Super Uber Club Member" - per Ira
    SCCoA Member # 705
    Nov 2004
    Brantford, ON
    5,383
    Move post to Technical.......
    Fraser
    Madison, Ohio
    17,692
    The best way to test for a vacuum leak is with a smoke machine. If you do use pressure, I do not recommend exceeding 20psi as you may blow out or damage seals etc.
    Email me here.
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Quote Originally Posted by SCrazy View Post
    Yes, definitely. I recently tested for and found a vacuum leak on my car with a similar setup. It was pretty easy once I found the right parts and fittings. What I did was to buy a vacuum / pressure hand pump, used for testing HVAC systems. Then I bought a tapered rubber plug of a size that approximately fit the IC tubes and throttle body. The plug had a small hole in the middle. I bought some 1/4" OD copper tubing. It fit nicely through the hole in the plug and made a good seal. At the other end, I used an adapter to mate it to the pump. So then I pumped while holding the plug in place and looked for the leak.
    In my case, I believe I found that it was leaking when I pumped air in at the throttle body. But I still couldn't isolate the spot. So I pulled the blower, plenum, and top IC tube off as a unit. I put the plug in the top port of the intercooler and verified that the intercooler, lower IC tube, return plenum, intake manifold, and valves were all sealing just fine. So I knew the leak had to be in the blower section. With the aid of some vacuum caps for the hard fittings and a buddy to pump while I blocked the IC tube end with my palm, I quickly found that there was a leak at the joint of the blower and inlet plenum.
    I will try to get some part numbers for you later, when I am at home. I do have this ... Here is a listing for the pump I bought. (I got a better deal by finding it used on eBay, but this price still isn't bad.) http://www.patriot-supply.com/produc...item.cfm/46171
    Booze for breakfast?
    God bless!!!
    Former Birds:
    Jul 2007
    South IL
    1,574
    brake cleaner works pretty good to.
    English, IN
    4,515
    I made a cap that clamps onto the TB out of a 3" rubber pipe cap (from Home Depot), a large hose clamp, and an old valve stem. If I want to check for leaks, I air up the air compressor (be mindful of pressure - like Dave said), then have someone let air into the gadget and listen/test for leaks. It's real quick, cheap, and works perfect.
    http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
    Matt Haub
    Shootouts: '09 SS 1st | '10 Mod1 2nd | '11 Bracket 3rd | '12 Bracket 1st | 2013 | '14 Bracket 3rd | 2015 | '16 Bracket 1st & Mod2 2nd | '17 Spectator | '18 Freeze-Plug Champ
    Black '89 5spd - 281K miles, MPx, Alky-Inj 387rwhp, 438rwtq (new motor) Best 1/4mi:12.521, MPH:107.23mph (old motor)
    Dallas, TX
    5,755
    Fastest and easiest way I've found to find to locate a vacuum leak is with a mechanics stethoscope. With the engine running, you can probe the lines and actually hear it. I don't know how well it works for a boost leak, but if I can find a problem 75% of the time that way, I've saved hours of troubleshooting.
    Madison, Ohio
    17,692
    Quote Originally Posted by slowpoke View Post
    Brake clean doesn't work at all for small leaks because the EEC will compensate faster than you can detect any change in rpm. Many a would-be mechanic has been fooled by this technique. Works for carburetors but not for a modern EFI where the EEC has control of ignition timing.
    Guys, smoke machine. It will tell you in 3 minutes every conceivable leak however minuscule. It's worth the money to have a mechanic test the vehicle and as I said, only takes a couple minutes, no rigging of anything required. Call around and find a mechanic willing to do it for you without charging $100.
    Pressurizing is ok for some things, but you still have to find the leak. If, lets say the bottom of your supercharger inlet was leaking, how would you find that? Smoke machine will tell you in 3 minutes while you drink your coffee, smoke a cigarette, whatever, no disassembly required.
    Email me here.
    Aug 2004
    KSRQ
    5,220
    Do you mean as simple as if you were checking for exhaust leaks?? What would you hook it up to, the TB?
    Ira
    Jan 2003
    Woodbridge, VA
    5,267
    Pump it in the CAI nipple or one of the vacuum lines on the blower inlet.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    East Hartford, CT
    3,498
    so if i picked up a leftover 500w holloween smoke machine and make up some ghetto adapter to blow the smoke into the intake pipe somewhere before the MAF the smoke with then work its way throughout the system and leak out of the smallest little leak?? Will the smoke machine pressurize the system? Do I need to block off the exhaust?
    Does anybody want to buy a lightly used smoke machine?
    edit: Wow those little smoke machines put out about 2500cfm, I'm sure the fan won't do alot of static pressure but it should force smoke through all kinds of stuff.
    Brian Oatway
    525rwhp/460rwtq
    SCCoA Member # 705
    Madison, Ohio
    17,692
    It will fill the engine with smoke and will leak out visibly from any and all orifices. Definitely don't want 2500cfm, more like 10 cfm if that. It doesn't push out very much smoke at all. It won't simulate boost, but it will find all vacuum leaks, guaranteed. It doesn't create any pressure in the system.
    Email me here.
    Jul 2003
    4,993
    Funny, that's exactly where my leak was. I knew there was a vacuum leak because of testing with starting fluid ... but it was not at all obvious where it was. It just wasn't precise enough. And the pressure test doesn't show you exactly the leak is ... since air is invisible and all. So that is why I had to remove some parts to isolate the leak. If I had a smoke machine or a knowledgeable / willing mechanic nearby, I guess that would have been more convenient. But it all worked out.
    Dave, you probably know this already, but your PM box was full earlier. To summarize what I was going to PM you, by mail it is.
    God bless!!!
    Former Birds:
    East Hartford, CT
    3,498
    I went to I-Party this morning and everything Holloween was 1/2 price. I got a fog machine and a gallon of fog juice for $26.
    Gonna see how this goes
    Brian Oatway
    525rwhp/460rwtq
    SCCoA Member # 705
    Aug 2010
    Wilkes-Barre, PA
    37
    dumb question...
    when testing for vacuum leaks with a smoke machine, should the car be running or off? i hate that i have to ask this lol
  1. Boost leaks, what they do and how to deal with it
    By Vernon in forum Technical Forum
    Last Post: 04-16-2013, 12:19 AM
  2. M90 Blower testing proposal:
    By XR7 Dave in forum Non Technical Forum
    Last Post: 12-09-2005, 08:18 PM
  3. Replies: 0
    Last Post: 03-05-2003, 04:03 AM
