Thread: sc oil cooler
    Jul 2007
    South IL
    1,574
    sc oil cooler
    just brain storming or possibly farting here. has anyone ever attempted an oil cooling system for our blowers. it wouldnt be hard to install a pick up and return line on the snout, a small res, tranny cooler with a small fan, and a low speed pump. needless to say keeping things cooler always helps but in this case would it help enough to make a difference? opinions, experience, ext here please. im looking for all views at this to decide if i want to try it as a winter project.
    May 2009
    31
    U have the exact same idea that i was thinking about doing this winter. I honestly think it could help after all anytime u can reduce heat u will make more power and run more efficent.
    Dec 2009
    Toronto
    2,103
    Definately supports the front end.
    Rear bearings and case heat may be bigger obsticles.
    Paul
  1. changed sc oil - eng runs cooler!!!
    By decipha in forum Non Technical Forum
    Last Post: 08-16-2010, 08:09 AM
  2. Anyone know how the oil life monitor works?
    By MadMikeyL in forum Technical Forum
    Last Post: 03-25-2010, 05:00 PM
  3. tranny cooler- oil cooler
    By slowpoke in forum Technical Forum
    Last Post: 03-06-2009, 01:12 PM
  4. Maintenance Schedule?
    By Flip in forum New SC Owner Forum
    Last Post: 08-31-2003, 07:36 PM
