Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 63
Thread: How to: 4r70w swap
  1. #46
    Dacono, CO
    1,209
    You can use the AOD shifter and cable, but any 94-97 t-bird and 93-95 mark VIII shifter will also work - and fit below the AOD consol just fine. 96-98 mark use a different style shifter that won't work.
    The advantage of having the 4R70W shifter is that is has a built in "O/D off" button, and the proper PRND21 read-outs. You can program the PCS to use a toggle or momentary switch (like the factory O/D off switch).
    After that video was taken, I had a guy on TCCoA (forget his name) make me custom gauge displays to replace the factory indicator lights (check engine, door ajar, etc) I had him add "O/D off", and "PERF. SHIFT", and "MANUAL MODE" in some blank areas that weren't used, then I powered them directly from the +12v programmable outputs on the PCS using led's. Looked like a factory fit and finish.
    You'll also need a 94-97 T-bird/Cougar shift lever if you are using a mustang trans. 93-95 mark VIII works too, but the 96-97 mark viii's I saw looked like they used a mustang shift lever. Alan will know what you need in that regard.
    You'll also need a 94-97 3.8L bird/cougar trans crossmember. The AOD one, or a 4.6L one won't work, you'll also need a 3.8L 94-97 cougar/bird driveshaft.. The v8 cars won't work, and the AOD/M5R2 driveshafts won't work either.
    Jeramie
  2. #47
    Aug 2002
    3,660
    This thread is made of solid win. Thanks Jeramie.
  3. #48
    20,909
    Yes great info...BTW, this is the next major mod I'll be doing on my 91 SC.
  4. #49
    Jul 2003
    Ottawa, Ohio
    5,400
    Looks like a need to download the pdf manual and the software to see what it would be like. Hope Alan will chime in about internals and converters.
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
  5. #50
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Quote Originally Posted by 92bird View Post
    Sounds cool. Could that have been Scott Hrbacek?
    God bless!!!
    Former Birds:
  6. #51
    Dacono, CO
    1,209
    Happy to help, I learned this all the hard way when doing it myself, through many trips to the junkyard..
    Originally I had bought a 4.6l bird crossmember and driveshaft, didn't work, had to use the 3.8L stuff.
    As for the simple shift, one thing I don't see is the ability to FULLY control converter lockup.. I think the limited programming just allows for adjustments. The $750 programmable version allows for more converter lockup adjustment parameters than you could dream of, including a "dyno mode" for locking the converter on the dyno.. David - this would improve your rwhp and rwtq numbers right here!
    But I wouldn't recommend a stockish replacment converter try locking up at WOT.. I did it once with my stock 04 maurader/mach 1 converter and it seemed to handle it ok in 2nd gear (you can datalog the trans and see slippage %) and it did not slip once engaged, but did have a slow engagement.. Hence why I only tried it once. Alan can chime in more on this - he can build purpose built converters for locking at WOT.
    Jeramie
  7. #52
    Dacono, CO
    1,209
    Yep that was him - did a great job.
    Jeramie
  8. #53
    Dacono, CO
    1,209
    One further point.. The factory 89-93 shift interlock won't work with the 94+ shifter.. I didn't care because I was converting a 5 speed car anyway that didn't have it..
    But, I sold the entire setup to my friend with a '93 SC auto, and ran into this issue.. The solution was to use the 89-93 shifter basket mechanism with the 94+ shifter and activation rod.. So in a sense, to have a "hybrid" shift unit. This allows the factory shift interlock to work (can't shift without key, can't shift out of park without brakes). Nobody would ever know the whole setup wasn't factory!
    Jeramie
  9. #54
    20,909
    Jeramie
    I would probably be switching to 4.10 gears and an Auburn Pro diff at the same time. With that stuff and higher stall lockable converter with the computer doing the shifting and controlling converter locking/unlocking...I could probably run 2 or 3 tenths quicker on the track and have a more street freindly set up than I've got now.
  10. #55
    Oct 2004
    Metro Denver Area
    2,514
  11. #56
    Dacono, CO
    1,209
    Bryce, you don't need the sleeve with that shaft, there are no holes drilled for a governer (an AOD piece only). That is only needed on '93 mark VIII shafts and very early 1994 Thunderbird shafts.
    Slap it in
    Also, check out www.clickclickracing.com, it is a forum for ford RWD transmissions, and is where I learned most of my stuff.
    Jeramie
  12. #57
    Oct 2004
    Metro Denver Area
    2,514
    Slap it in
    Jeramie
    ok, thanks
  13. #58
    Dacono, CO
    1,209
    Also, make sure to re-use the return spring from the '94 overdrive servo on the '04 servo.. It will get rid of the slippery part throttle shift when cold. I still haven't been able to completely tune that out of steve's car.. So doing this will save you the headache..
  14. #59
    Oct 2004
    Metro Denver Area
    2,514
    What color was that one?
  15. #60
    Dacono, CO
    1,209
    I don't remember.. Find the one that came out of the '04 trans, and match it up with the box of spare trans parts you got with the car. It should look the same but might be a different color.
  1. 1997 thunderbird 4.6 to 5.4 swap.
    By DSM in forum Technical Forum
    Last Post: 09-14-2010, 01:45 PM
  2. Replies: 5
    Last Post: 05-17-2010, 05:23 PM
  3. Question on 2003 mustang 4R70W swap into 94 sc
    By 92bird in forum Technical Forum
    Last Post: 01-21-2010, 02:51 PM
  4. 4R70W Mustang swap?
    By Blown 91 Bird in forum Technical Forum
    Last Post: 12-20-2005, 08:52 PM
