Results 1 to 15 of 18
Thread: aod pi 9.5 converter dirty dog has redone it
    Sep 2009
    66
    this unit started life as a pi aod locking converteror direct drive what ever you car it, then i sent the converter to Alan at dirty dog performance and re don the stall with a #7 pump 82 stator about a 3500 stall, im changing to a 4r70w trans and have no use for this im sending this to dirty dog to double check everything converter worked fine when removed but this was if you need stall change its not a big deal, it will be shipped directly from Dirtydog performance to the new owner, so this will be like a brand new converter opnce again after Alan goes thru it best 60ft to date was 1.51 but it was a 5.0 fox bird with traction issues
    360 shipped
    any questions just ask
    Robert
    Aug 2004
    Batavia,OH
    2,019
    Bump, for those with stock power levels or just above the stall on this unit would be about 2800 at 350hp it would be about 3200.
    Alan
    May 2009
    Mansfield
    337
    Is this convertor still around?
    Sep 2009
    66
    It's still here waiting to be sold so it can be sent to dirtydog to be checked out then to the lucky buyer
    May 2009
    Mansfield
    337
    So is this still a locking tc? I'm Just setting up a paypal acct. I assume that's how you want payment?
    Thanks Tom
    Sep 2009
    66
    Yes it is still a locking converter, as soon as payments received, it will go to dirtydog for refreshing, even though it worked great when removed, but I'm paying for him to go thru it, that way we know it's perfect
    Robert
    Aug 2004
    Batavia,OH
    2,019
    AOD torque converters do not have lockup. They have direct drive and it is still in place in this unit. If you exceed 350ftlb of torque I highly suggest eliminating the direct drive in the unit to relieve the strain on the transmission and input shaft. It can be removed.
    Alan
    May 2009
    Mansfield
    337
    I only plan mild mods on my car and want to maintain the best fuel mileage I can as I do a lot of highway driving. Robert p I'll pm you tomorrow once my paypal is set up.
    Cheers Tom
    Aug 2004
    Batavia,OH
    2,019
    The direct drive still has ratio loss, it is not a true 1:1 because the speed of the other shaft helps to set the ratio leaving the converter still slipping. It is a strange design. Everyone is afraid to remove it, but once you do you'll never go back.
    Alan
    May 2009
    Mansfield
    337
    How much will removing it affect fuel mileage? It's my daily driver and with fuel expected to continue to rise significantly every little bit makes a difference. What are the benefits of removing it?
    Tom
    Aug 2004
    Batavia,OH
    2,019
    It will make little to no change on roads below 55mph and the loss will be a little worse above 55. If you drive the highway often keep it, otherwise ditch it.
    Alan
    May 2009
    Mansfield
    337
    Robertp, you have a pm.
    Sep 2009
    66
    no pm there just email me [email protected]
    May 2009
    Mansfield
    337
    Robert, I tried paypal again, I think it went through this time.
    Tom
    May 2009
    Mansfield
    337
    Tom
  1. 9.5 inch AOD converter group buy (CLOSED)
    By Dirtyd0g in forum Group Purchases / Specials
    Last Post: 01-16-2010, 02:05 PM
  2. Dirty Dog 2600 stall AOD converter
    By rzimmerl in forum Parts for Sale
    Last Post: 10-06-2009, 09:51 PM
  3. Inside an AOD converter 56k, take a nap
    By Dirtyd0g in forum Technical Forum
    Last Post: 09-19-2007, 01:46 AM
  4. A good post I found for you AOD guys out there.
    Last Post: 12-31-2005, 11:05 AM
