Long cranking time when starting
bkosonen
Hey guys. My car has starting having a long cranking time when I go to start it. Dident do it tell I put some 104 octane booster in it. Question is if you put the full thing of booster in with like 8 gal. Of gas could that cause it? Also not sure when the fuel filter was done eather.
Bump ? It dosent do it all the time but when it dose and when it starts the tach dosent work but then starts working.
Sounds like a bad cam position sensor.
91-93 octane is plenty, that octane booster stuff doesn't sactually increase the octane, it just has the effect of increasing octane. I think the stuff is worthless and is more likely to make your car run worse, than better.
