Results 1 to 9 of 9
Thread: Power windows issue...acts like it is not finished rolling up!!
    Aug 2002
    Rock Hill, SC
    786
    When I roll up my passenger side window in my 89 SC, whether it be up or down, when it gets all the way down or up, and if I continue to hold the switch, it will like act like it wants to keep going, making a thump, thump, thump sound when the motor keeps turning. Anyone experienced this?
    Oct 2010
    just north of Greenbay
    14
    i have the same problem but my windows dont roll down at all just the thump noise
    Oct 2004
    Charlotte, NC
    8,159
    The plastic plugs in the window motor that drive the regulator are worn out and need to be replaced....
    You will eventually get to the point where the window will not go up or down....
    Oct 2010
    14
    how hard is it to replace
    Oct 2004
    Charlotte, NC
    8,159
    Not too bad....
    Remove door panel....
    Remove door speaker.....
    Remove three bolts that holds window motor to window regulator....
    Remove window motor through speaker opening in door....
    Remove screws that hold the cover down and the C-clip on top of the small gear.....
    Lift everything out and you will see the bits and pieces of the broken gear plugs.....
    Thoroughly clean everything out and install a new set of plugs (Look for them in the HELP section of the parts store)....
    Hardest part is removing and re-installing the door panel....
    Or is it installing the plastic plugs.....
    Jan 2010
    Bossier City, LA
    2,221
    Quote Originally Posted by the-big-e View Post
    Hardest for me, on the driver's door, was screwing the bolts in lefthanded. I don't screw well left handed ...
    Let's add "Be CERTAIN to a) get all the old busted plugs out, and b) lube the sucker up. GOOD." As in "Clean out the old, fill it part way, put the big gear back in, put the plugs in, fill THAT cavity up, put the metal gear in, fill the REST in." I used lithium, but I'm about to redo the passenger side and I'll use moly suspension grease there.
    RwP
    Oct 2004
    Charlotte, NC
    8,159
    I use a flat blade jewelers screwdriver to dig all the pieces out of the recesses in th big plastic gear....
    Jan 2010
    Bossier City, LA
    2,221
    Take the big gear out and flush it with compressed air then wash it with alcohol (not as good in the winter, due to freezing the hands due to evaporation, but eh.)
    Got to get it out to relube the bottom anyway.
    RwP
    Mar 2008
    easley south carolina
    226
    phil, i replaced those plugs in the window motor and reglued the window to the tabs in the track last summer.
  1. electrical issue with FUSE 18
    By pastera in forum Technical Forum
    Last Post: 04-01-2003, 04:42 PM
  2. power windows
    By Platinum90SC in forum Technical Forum
    Last Post: 02-08-2003, 02:56 PM
  3. Replies: 1
    Last Post: 10-04-2002, 08:05 PM
  4. need help with power windows
    By DUKSRULE in forum Technical Forum
    Last Post: 07-18-2002, 05:37 PM
