*She's not for sale any longer. I apologize to the interested parties.*
I need a more dependable daily driver. This one has to go.
I'm in Greenville South Carolina
$2000
1994 Ford Thunderbird Super Coupe
5 Speed
Black/Grey Split Leather/Cloth Interior
Sunroof/Moonroof
Has a '96/'97 hood and headlights with clear corners. The hood and bumper are primer black
What's been replaced in the past 5 years:
SPEC Stage 2 Clutch
190lph fuel pump
Battery
Alternator
BHJ Harmonic Balancer
New UCA's w/balljoints
Front shock tower bar installed
B & M Ripper Shifter
Rock Crusher Shifter (will find pics)
Replaced seat panels with black ones (see pics)
New motor mounts
New power steering pump and lines
New supercharger coupler and fresh fluid
Edit: Upgraded to dual piston Mustang calipers
I have a bunch of parts that will go with the car:
IRS poly bushing and rear knuckle bushings
Sunroof motor (mine sticks. You have to push it a little to get it to open. May just need to be lubed up.)
Stock exhausted manifolds (was going to have them ported)
Antenna (mine is slightly bent)
May have more parts laying around.
The Bad:
Passenger side fender is scraped from previous owner (see pics)
Driver's side lumbar doesn't work
Odometer is broken (135,XXX)
Interior has a cig burn in passenger seat from previous owner(s) (see pics)
Transmission leaks a little
Paint is starting to peel on the trunk and top of the car.
The radio/speakers need to be rewired. They work but there's some loose connections.
A/C compressor locked up. It's getting replaced next week with a spare one but the a/c will not be hooked up. I'd suggest replacing the a/c components if you want working air. My ex rigged the low pressure switch with a paper clip and I believe that's what caused the compressor to go.
It's a 16 year old car. It's not perfect. I drive 50+ miles per day and need something more reliable and gas efficient. I have my eye on my friend's Honda Accord that he is selling and I'd like to jump on it soon.
Pictures:
Shifter:
Ground effect on passenger side:
Scrape on fender:
(I need to get some current pics with the '96/'97 hood and lights)
If you have any questions don't hesitate to ask. I'm sure I forgot something.
Thanks!
$2000
5 Speed
Sunroof/Moonroof
SPEC Stage 2 Clutch
190lph fuel pump
Battery
Alternator
New motor mounts
The Bad:
Pictures:
Shifter:
Scrape on fender:
Thanks!
