92sclikenew
when you guys said they had a shoulder i was thinking like a built on washer..
Just FYI, the parts catalogue shows the manual trans SC flywheel bolts as M10 x 1.0 x 24 mm long. P/n is E2TZ 6379 A. They are going obsolete, but some stock is still available from the Memphis warehouse.
Yep, I'm a believer.
rlittlep, I see you haven't completed your 5 speed swap so now might be the time to double check the bolts.
90coug:
Just checked the bolts..You DID sell me auto's. I checked the pics then the bolts and you can see that only about 4-5 threads were holding the flywheel on. Guess I NEED to get the correct ones by spring.....
