Results 1 to 15 of 29
Thread: Door Striker Help
    Oct 2006
    va beach,va
    2,585
    Door Striker Help
    My bushings gave up on the door strikers. I went to Advance Auto and picked up a stiker bushing kit. They are too large for the bolt and wont allow the door to close. Waste of 8 bucks. Anyway, I am wanting to just replace the strikers. Anyone have a part number I can search for? I found these on Ebay but not sure that they are correct. http://cgi.ebay.com/ebaymotors/NEW-D...Q5fAccessories According to the part match thingy on the auction itself, they wont. They look correct though. Any ideas? Are they available from Ford any longer?
    Oct 2004
    Charlotte, NC
    8,160
    I found them in the HELP section at Advanced Auto....
    There are two different kinds for the Fords....
    One has a slightly larger bolt than the other.....
    Oct 2006
    va beach,va
    2,585
    Quote Originally Posted by the-big-e View Post
    Yeah I walked in and found them right away. It was a kit of four. Two shorter than the other two. They dont fit the bolt(Loose) and they wont allow the latch to close over them. The diameter is too great. The door just catches on the edge and gets stuck on the bushing. Def not correct. So there is a different kit? Did yours have four bushings or just two?
    Oct 2004
    Charlotte, NC
    8,160
    It only has one...
    Jan 2010
    Bossier City, LA
    2,308
    Quote Originally Posted by frdlvr30 View Post
    The proper kit (Dorman # 38445 - HELP! number is the same or very similar) is what you're actually looking for - it's the bolt, the plastic bushing, and the metal bracket.
    The bushing kits are a total waste of money - none of them match.
    Before you cruise the HELP! area (or the UNEEDA area, almost identical numbers - or MotorMite, again, same family!) I'd check the cross reference at www.dormanproducts.com .
    RwP
    Dec 2008
    Morganton, NC
    4
    The four bushing kit is for a Ford truck tailgate. They will not work on your striker bolts.
    Jul 2003
    Eastern (nee Western) PA
    4,993
    It's quite annoying, but you can't buy the bushing separately. I also measured the bushings to see if they would cross-reference to any known size of plastic pipe, but it's a very odd size. I think it's 12mm inside and 14.8mm outside. Neither dimension seems to be a common size of pipe, so simply cutting new ones for pennies apiece seems to be out of the question. I talked to a club member who lathes things about fabricating some, but he said the cost in materials and time would probably be greater than the $9 apiece we have to pay now.
    If anyone knows where to find 12mm ID plastic pipe, or 14.8mm OD plastic pipe, let me know!
    God bless!!!
    Former Birds:
    Oct 2004
    Charlotte, NC
    8,160
    That's the same thing that I had thought of...
    I could make my own, but it just wouldn't be cost effective for me to sell them....
    I have found some good ones in the junk yards....
    Passenger side door strikers seem to last longer than the drivers side....
    Mar 2007
    Central Kentucky
    767
    the ones off back doors on some vehicles work really well too...I picked up a half dozen from the local Pullapart.....Dan
    I don't think I have ever owned a car that was finished---unless it was totaled.
    Oct 2006
    va beach,va
    2,585
    RwP
    Thats what I was looking for.....thanks!!
    Oct 2006
    va beach,va
    2,585
    Ordered two of the 38445's....
    Mar 2006
    Delta, BC, Canada
    642
    I just took some passenger side hinges I had and flipped them. Door works great now.
    Sean
    Dallas, TX
    5,755
    I take a milk jug, cut 3" long strips the width of the bushing, wrap them around the post a couple of times and secure with 2 zip ties.. one at each end where the latch doesn't catch the zip tie.
    Nov 2010
    johnstown,pa
    292
    How about aluminum? I have been using electrical tape. I have a buch of solid round aluminum and some aluminum tubing. I was gonna turn some out on the lathe but i was worried there might be a reason they used plastic. If someone can get me an o.d. of an actual bushing in thousands i'll make a bunch and hook you guys up. I can make them out of schedule 40, cpvc or aluminum.
    Sep 2006
    Lower Westchester, NY
    1,428
    http://supercoupeperformance.com/par...spx?partId=284
    at least you know it'll be 100% right
