Results 1 to 13 of 13
Thread: what the heck is this noise? Video inside
    SCCoA Member#1257
    3,297
    Can you guys help me pinpoint or suggest where to start? The car has new eibach springs and KYB shocks with new strut mounts. The noise as you can see can be replicated when the passinger side corner is pushed down, or when the steering wheel is moved. It sounds like a bushing going bad but not sure. I figured I'd get your thoughts on it. Thanks in advance for the suggestions.
    20,928
    Sounds like upper control arm bushings. Rather than replacing the bushings, most people just replace the entire upper control arm.
    Nov 2004
    Brantford, ON
    5,383
    Did you load up the suspension before you torqued everything down?
    Fraser
    Jul 2007
    South IL
    1,571
    autozone has a cheapo stethoscope for around $10. weed that in to each knuckle while you have a helper simulate the noise. thats the best way i can think to track exactly whats making the noise.
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Those are almost certainly two separate noises. For the first one, I agree with David. It's probably the UCA bushings, especially if they are the original UCAs. There was a TSB about those long ago, because they made a noise like that when cold.
    The second one sounds pretty bad ... bad ball joints, rack, or steering pump, would be my guess.
    God bless!!!
    Former Birds:
    1990 SC auto ... red outside, gray cloth inside ... ~225,000 miles ... Sold.
    1990 SC auto ... white outside, gray cloth inside ... ~150,000 miles ... wrecked.
    1989 Base auto ... Crystal Blue metallic outside, dark blue inside ... ~160,000 miles ... Sold.
    Amarillo, Texas
    471
    I had the same noise on my 93 and it was the upper ball joint. Just an idea
    Oct 2009
    Spokane Wa
    1,209
    dry and just plain worn out ball joint. get under there and inspect and like said before get a stheoscope.
    May 2004
    Bmore
    3,228
    How do you load up the suspension before tightening everything down. Not to highjack the thread but once the car is lowered, I cant get under there to torque it all down.
    Jul 2003
    4,993
    Quote Originally Posted by Dahoopd View Post
    You could use ramps. Or you can get close by using jackstands under the LCAs so it sits at something like ride height. Obviously, be careful, and use a backup lifting device for safety.
    God bless!!!
    Former Birds:
    May 2009
    Grand Rapids, MI
    193
    Had the same noise over the past few summers. Changed my ball joints last summer, and still have the noise. Great to know that others are dealing with it also. Please let me know what it turns out to be, i'd really like mine to go away
    Also, does it make noise sometimes around turns?
    Mar 2004
    Boise, Id
    529
    That sounds like dry upper control arm bushings. Try to spray some wd40 on the bushings and see if it stops it temporarily. The upper bushings you can tighten under load easily. These are the ones that are under the hood. Try backing the 18mm nuts off and then push up and down and see if the noise is still there. If its not, spray some white grease in there and then tighten to spec.
    5,129
    My lower ball joint started sqeeking. It also made the steering stiffer. And pulled to the bad side under brakeing.
    SCARlit on drag duty now
    SCCoA Member#1257
    3,297
    Quote Originally Posted by fturner View Post
    Fraser
    I was under the impression that this was only necessary if you did work on the control arms and joints...not when doing springs and shocks.
    Quote Originally Posted by S_Mazza View Post
    Kudos on your observation skills my friend, the car does indeed have a noisy steering pump but that noise is only slightly perceivable in the video...the noise in the video is pretty much all noisy suspension.
    I guess i'll try fiddling with those bushings to see if there is any change in noise...if so, i'll get the upper arms replaced.
  1. Best Guess on Engine Noise
    By richuncle in forum Non Technical Forum
    Last Post: 07-28-2011, 10:17 AM
  2. Help diagnosing wheel bearing noise
    By 90turbo1 in forum Non Technical Forum
    Last Post: 11-12-2010, 11:30 AM
  3. Possible Explanations for Noise from Rear End Needed Inside
    By Phillio99 in forum Technical Forum
    Last Post: 03-03-2010, 01:07 PM
  4. Gauging interest in a shootout video.
    By Jeremy_K in forum Non Technical Forum
    Last Post: 11-01-2005, 09:58 AM
  5. irregular noise from clutch...??
    By CaifanSC in forum Technical Forum
    Last Post: 12-10-2003, 12:17 PM
