Thought that I'd share my project with everyone over here. I mostly post on V6power since I have the M90 on my '98 Stang.
I was going for the Magnum Powers MPX inlet port style. I started with a early style blower case.
I welded in some aluminum strips and cleaned it up with a carbide burr. Then I faced it off in my mill.
Ported the top outlet a little.
Cut out the inlet plate out of 1/2" thick aluminum.
welded some 1/4"th by 1" aluminum to add to the inlet plate.
Welded the 1/4" by 1" aluminum piece to the inlet plate. Now I just need to clean it up with the burr. Then I'll mill it flat. Then start fabbing up the rest of the inlet.
Just finished casting a front outlet SC top out of aluminum. I built a foundry furnace last summer, so I though I'd put it to use. Just need to clean it up and mill it flat.
