Last night the headlights started flashing on and off. Parked the car figuring the headlight relay was shot. Got up this morning and the electrical command center would not turn on. Stayed dark. The turn signals would not work. The brake and ABS warning light both stayed on. After driving for ten minutes the brakes failed with the pedal getting hard/ no power assist. OK, is it all interrelated or just dumb luck things going all at once? Is it related to the recall dash wiring harness short problem? Take to the dealer? Take it to private garage? Any and all help and incite will be appreciated. Thanks.
