Results 1 to 10 of 10
Thread: Rear Wheels Not Centered
    Aug 2007
    200
    Question Rear Wheels Not Centered
    Does anyone know why on some MN12s (mostly later model ones), the rear wheels are not centered in the wheel opening, but are forward a couple of inches?
    Michael
    Nov 2005
    Fort Wayne, Indiana
    2,985
    Quote Originally Posted by Cyboman View Post
    Michael
    I have never heard of that, but I would have a 4-wheel alignment done because that is what caster adjustment changes. Worth a check at least.
    my email
    Boston, MA
    7,356
    Very common, my car is one of them. I take there is some adjustability on the main IRS mounts. Ive never taken down my IRS unit so it was that from the start. You could try to recenter it but I dont see issues as long as the wheels are aligned to compensate.
    Oct 2009
    Spokane Wa
    1,209
    Quote Originally Posted by mywhite89 View Post
    threre is no castor measurement for rear wheels.
    like said there is probably someting moved in the rear of the car, an alingment is probably needed anyway.
    Nov 2005
    Fort Wayne, Indiana
    2,985
    Hmm, sorry about that. been a long time since I did mine. Now I think of it, I guess theirs not, unless you can move the whole subframe a bit.
    Chris
    my email
    Aug 2007
    200
    The issue is it just doesn't look right. The wheel should be centered in the opening. If one were to go with bigger (say 20") wheels it would look worse, and could possibly rub in places where it would not otherwise.
    Does anyone know if the subframe could slide back in it's mounts that much to correct this?
    Michael
    Nov 2010
    johnstown,pa
    292
    Could be worn out control arm bushings.
    May 2011
    825
    20 inch wheels are for one ton trucks.
    Boston, MA
    7,356
    Michael
    There has to be some play, if its worth the hassle to you back out the IRS bolts and lift the body with a jack and push to the side the body and set it back down then rebolt it. But if you are in a rust prone area I would not attempt it.
    Feb 2008
    138
    My 96 is like that too, I've seen it before. Oh, and I had Ford do an alignment just a couple of months ago. I watched the tech adjust the right rear wheel alignment slightly.
  1. 04 Explorer rear internals in SC/Mark 8 rear???
    By Mercury267 in forum Technical Forum
    Last Post: 02-22-2006, 06:21 PM
  2. Press or Tool Recommendation for Rear Wheel Bearing Failure?
    By Don Teeple in forum Technical Forum
    Last Post: 05-30-2004, 04:24 PM
  3. rear wheels hop
    Last Post: 05-13-2004, 02:32 PM
  4. front versus rear wheel drive wheels
    By Ronald Wendt in forum Technical Forum
    Last Post: 06-06-2003, 10:20 AM
  5. rear wheels
    By stephens89sc in forum Super Coupe Club of Western Canada
    Last Post: 09-15-2002, 02:27 AM
