Results 1 to 2 of 2
Thread: 5.0 5-speed 1989 XR7 $2000
    Oak Ridge, TN
    1,691
    Original 5-speed car. 5.0 conversion completed last April and I've been driving it almost everyday since then, over 16,000 miles. Maybe not 100% complete(the 5.0 swap), but 99%. I haven't installed the 1991 stand alone cruise control system, the check engine light is on because the ecu thinks it still has an egr valve, and the oil pressure sensor needs to be switched(the gauge is pegged high). Also the A/C is not hooked up, but it wasn't before.
    Engine/ecu/wiring harnesses came out of a 1991 XR7 with not much over 100,000 miles.
    Many of the new parts installed, during the last year, and pictures can be found in my garage:
    http://www.sccoa.com/forums/garage_v...vehicle&id=122
    I've recently installed a new distributor and radiator.
    New parts installed when converted to 5.0:
    Powermaster starter
    flywheel
    clutch/release bearing
    SCP solid motor mounts
    shorty headers
    complete power steering rack with poly bushings and new lines
    poly sway bar bushings
    battery
    summit harmonic balancer
    summit underdrive pullies(alternator pulley not installed)
    water pump
    93 gas tank
    I have had the car since 2003 when I bought it in South Carolina and it has been here in Tennessee after that so it is very solid. Exterior is it's weak area but is mostly cosmetic problems from 20 years of use, plus some very small hail dings from a recent storm.
    Oak Ridge, TN
    1,691
    Price reduced to basically the cost of all the new parts installed since last year.
    This car took first place in the 2010 SC Shootout Horsepower competition in the naturally aspirated V8 category.
    Dyno'd 204 HP and 270 torque. Ok, so it was the only car in the category. It still did pretty well and ran 14.77@ 92.13mph.
  1. I found this FAQ on the SC
    By Active non member in forum Super Coupe Club of Western Canada
    Last Post: 12-21-2013, 02:28 AM
  2. 89 XR7 Black 5 speed $1500 Very Clean
    By BRIAN WALTER in forum Cars for Sale
    Last Post: 02-18-2010, 11:52 PM
  3. F/S White 89 XR7 5 speed w/ 72k original
    By 895speedXR7 in forum Cars for Sale
    Last Post: 01-16-2005, 01:54 AM
  4. 1989 Mercury Cougar XR7 for sell.
    By chamilion z in forum Cars for Sale
    Last Post: 01-10-2005, 11:59 AM
  5. 1989 Mercury Cougar XR7 for sell.
    By chamilion z in forum Super Coupe Club of the Midwest
    Last Post: 01-10-2005, 12:02 AM
