I'd like to do a fairly even swap (could throw in a few hundred, not much more) for a 4 door car or SUV. Must have A/C and heat! My husband and I found out I'm pregnant and we need a different car. He has a Mustang and I have the SC. Not very baby friendly. Not to mention my car doesn't have A/C.
I may travel a small distance for the right car, but with mine and my husband's work schedules it's difficult.
1994 Ford Thunderbird Super Coupe
5 Speed
Black/Grey Split Leather/Cloth Interior
Sunroof/Moonroof
Has a '96/'97 hood and headlights with clear corners. The hood and bumper are primer black
What's been replaced in the past 5 years:
SPEC Stage 2 Clutch
190lph fuel pump
Battery
Alternator
BHJ Harmonic Balancer
New UCA's w/balljoints
Lower balljoints
Front shock tower bar installed
B & M Ripper Shifter
Rock Crusher Shifter
Replaced seat panels with black ones
New motor mounts
New power steering pump and lines
New supercharger coupler and fresh fluid
Upgraded to dual piston Mustang calipers
I have a bunch of parts that will go with the car:
IRS poly bushing and rear knuckle bushings
Sunroof motor (mine sticks. You have to push it a little to get it to open. May just need to be lubed up.)
Stock exhausted manifolds (was going to have them ported)
Antenna (mine is slightly bent)
May have more parts laying around.
The Bad:
Passenger side fender is scraped from previous owner (see pics)
Driver's side lumbar doesn't work
Odometer is broken (135,821)
Interior has a cig burn in passenger seat from previous owner(s) (see pics)
Transmission leaks a little
Coolant leak. Haven't tracked down where it's coming from.
Paint is starting to peel on the trunk and top of the car.
The radio/speakers need to be rewired. They work but there's some loose connections.
Passenger side door panel's clips are all busted. I have the panel still.
A/C compressor locked up. There's another compressor on there just for the belt. No idea if it works or not. A generous member here shipped it to me so I could route the belt.
It's a 16 year old car. It's not perfect.
I'll snap a few pics tomorrow of the updated hood and headlights.
The clear coat peeling appeared about a year ago, much to my dismay
5 Speed
Sunroof/Moonroof
SPEC Stage 2 Clutch
190lph fuel pump
Battery
Alternator
Lower balljoints
New motor mounts
The Bad:
