Results 1 to 12 of 12
Thread: Leaking ABS Pump Motor?
    Aug 2010
    18
    1991 Thunderbird SC. I replaced the accumulator ball last year. Everything was good until recentlyÖ Brakes were leaking fluid from under the master cylinder reservoir (enough to leave a big puddle under the car). Took the car to my mechanic, and he says it looks like it is leaking from the ABS Pump Motor (part #E9SZ2C256A). Of course, that part is discontinued. He doesnít want to take it apart to far, in case we canít get a replacement (or in case itís monumentally expensive). So, he asked me to do some research for him.
    Where can I get a replacement for this part? Is it possible the part itself isnít bad, and it just needs a gasket? What is involved in replacing this? Suggestions?
    Jul 2003
    Eastern (nee Western) PA
    4,993
    It could just be a hose ... there is a rubber hose under the ABS unit.
    http://www.sccoa.com/forums/showthre...=abs+hose+leak
    http://www.eastcoastrollingthunder.c...sg3941#msg3941
    It could be leaking from the pump motor, as well.
    Rebuilt units are available from a few places ... although I forget exactly where at the moment.
    A member here called "the-big-e" usually has a few good used units for sale.
    But I would check the hose before buying anything.
    God bless!!!
    Former Birds:
    Oct 2004
    Charlotte, NC
    8,159
    Big E to the rescue.....
    The front seal on the pump motor has failed letting brake fluid into the pump motor housing.....
    It's a good thing you are repairing this problem.....
    If you continue to allow brake fluid into the pump motor housing, it will eventually corrode the insides and seize up the motor.....
    I have some pump motors that have been reconditioned, including new seals and bearings....
    They are not that hard to replace.....
    Definitely check the supply line hose that goes from the reservoir to the pump.....
    Give me your zip code and I'll quote you a price that includes shipping....
    Jul 2011
    Washington State
    6
    ABS pump motor needed
    Hi Big E,
    I'm wondering if you have any additional reconditioned ABS pump motors
    I also have a puddle under the car and have already checked the reservoir to pump hose and it is all dry
    ABS pump motor very oily
    I look forward to your reply
    I can also be reached 253.732.5846 98467 zip code
    Steve
    Oct 2004
    Charlotte, NC
    8,159
    Yes, I have a freshly rebuilt pump motor ready to ship.....
    PM sent.....
    May 2003
    Robinson, Pennsylvania
    1,122
    mine was the sensor leaking to the rear brakes for the ride control . i went to the junkyard and found a sensor to fit off a master cylinder from a lincoln it screws on and plugs in and does not leak but the car stays on firm ride
    ralph
    Oct 2004
    Charlotte, NC
    8,159
    Unplug the sensor and see if the light goes off.....
    If it does, then the sensor is bad.....
    Had this happen to my 92....
    Jul 2005
    LIVE IN OREGON NOW WOULD LIKE A CHAPTER HERE.
    80
    Motor
    I know this is an old thread but i need a motor do you happen to have one still or know where i can find one. Thanks.
    Aug 2010
    18
    Quote Originally Posted by USCFOOTBALL View Post
    I had to look back through my notes, but I believe I got the replacement motor from "the-big-e" on this forum (in this thread). He was very helpful in diagnosing my problem, and had the part I needed.
    Norcross, GA
    3,314
    You can also check with Jose Nunez, The ABS Tech, in Dallas 214-579-7846. He can rebuild the pumps & motors if you can't find one. I had one that kept on leaking and it turned out to be the high pressure switch that screws into the pump. I had it out and back in 3 times and it still leaked. Sent the ~~~'y to Jose and he found the pressure switch was the cause of the leak. They are available on eBay used for about $100. As long as the plug pins are the same it'll work. On my 2 SCs one is from a Saab Turbo and the other is from a Jaguar. They both fit and work.
    Jul 2011
    Broken Arrow, Ok.
    145
    Abs pump
    Quote Originally Posted by Mike Puckett View Post
    There are twp NOS units available on e-bay. A little pricey, a little under $
    400. each.
    PERSONAL LUXURY SPORTS CAR 1955-57
    PERSONAL LUXURY PERFORMANCE CAR 1989-95
    Jul 2005
    407
    Good afternoon
    The TEVES II complete unit and pump are available from Summit Racing
    https://www.summitracing.com/parts/a...el/thunderbird
    You could also search salvage yards for 1989 Lincoln Continental complete TEVES II. In my experiences they appear to be in much better overall shape (evidence of pump leak failure) than found on Cougars, Lincoln Mark VII and Thunderbirds. I have one as a backup. The complete unit (including the pump) can be interchanged with 1989 -1992 Thunderbird S/C. Note the Autozone pump price 1990 Thunderbird SC.
    http://www.autozone.com/brakes-and-t...otor/47877_0_0
    1989 Lincoln
    http://www.autozone.com/catalog/comm...-4411/4/image/
    1990 Thunderbird SC
    Good Luck.
  1. ABS pump motor replacement....
    Last Post: 02-23-2011, 09:28 PM
  2. Continued ABS woes (and others)
  3. Abs Pump Motor Turning On Too Soon???
    Last Post: 01-15-2005, 02:27 AM
  4. ABS Pump Motor
    By boosted89SC in forum Technical Forum
    Last Post: 07-10-2003, 10:38 PM
