Page 11 of 12 FirstFirst ... 789101112 LastLast
Results 151 to 165 of 166
Thread: Cobra brake 11.65" rotor upgrade kit.
  1. #151
    May 2011
    Glendale Heights IL
    247
    So he did, sorry I missed that part. I will be ordering a set of these in the near future, unfortunately now is not that time.
  2. #152
    4,418
    Got a set of these from Dave this summer and I'll say, this is a beautiful kit...too bad it gets hidden from view! Top-notch quality too!
    I ended up having the parking brake nub problem too. My car has calipers and e-brake cables from a Mark VIII on it...which are apparently a good bit different than the SC calipers. E-brake cable tensioner from a Mark VIII is a cool upgrade, btw...
    I was able to get the nubs into the bracket okay, but the Allen bolt head pops the cable out of the bracket when you try to pull the e-brake! The Mark VIII calipers don't have a cast recess for the nub to sit in like the SC's...it'll a flat steel bracket instead, which is part of why it pops out easily.
    So if you're doing a Mark VIII install, be careful that you read Dave's Facebook writeup and check your clearances and test your parking/ e-brake multiple times. It may go on without too much trouble, but it may still pop off!
    I have not fixed mine yet, but I suspect that grinding down the bolt head some may fix it. I really don't want to have to touch the nub-end of the cable.
  3. #153
    Palos Heights
    2,316
    11.65
    Hi Dave..check your private messages......Tracking number for WU is there.....Thanks, Ron
  4. #154
    Palos Heights
    2,316
    11.65"
    Thanks Dave...the brackets arrived today..............Thanks...larger brakes all the way around for the 2017 seasonName:  94BHF.jpg
  5. #155
    NE PA
    495
    Dave,
    Do you have any sets available?
    Thanks,
    Mike
  6. #156
    Madison, Ohio
    17,600
    Quote Originally Posted by 99GSXR750 View Post
    Dave,
    Thanks,
    Mike
    Yes, I have them in stock ready for shipping. 2017 pricing is $100 w/o brake rotor rings, $110 with. Paypal is mdkracing@windstream.net for same day shipping.
    Thanks,
    Email me here.
  7. #157
    Jan 2015
    Tidewater area, Virginia
    240
    Quote Originally Posted by CougarXR/7 View Post
    That is the most awesomely bad a$$ looking TBird. If it were mine I'd sleep in the garage
    95 5spd Pearl White SC, "Millennium TBird" (erst Dr. Jekyll)
    95 Automatic Red SC
  8. #158
    NE PA
    495
    Thanks,
    Dave,
    Any chance I can send you a check or do you only accept Paypal?
    Thanks,
    Mike
  9. #159
    Aug 2018
    1
    Are these kits still available?
  10. #160
    Nov 2009
    Upstate, South Carolina,USA
    63
    Quote Originally Posted by Rangerob View Post
    Email Dave. He may not be checking in on the forums. mdkracing@windstream.net
  11. #161
    Aug 2018
    3
    Hello,
    I would greatly appreciate if someone could help me here. I don't completely understand what's involved with all of this.
    I would like to upgrade my rear brakes and I would also like to go with the 5 on 4.5" B.C.D..
    Dave's brackets are exactly what I need. My question regards the Cobra hubs.
    Are the '99-2005 Cobra hubs a direct fit for the Thunderbird rear uprights?
    A quick eBay search found these:
    https://m.ebay.com/itm/FORD-PERFORMA...-/280269703516
    Are these what I need?
    I am rebuilding the entire rear end so I will be installing new rear bearings as well as rotors and calipers, etc..
    If I purchase these hubs, should I buy bearings for a T-Bird or a 2004 Cobra?
    If these hubs will fit my T-bird up rights without any significant modifications, should I also purchase the Hub rings from Dave?
    Thank you very much for any help you can give me with this.
    Dave
  12. #162
    5,186
    Quote Originally Posted by Chopchop View Post
    Hello,
    Dave
    Yes those hubs will work. Can get bearings for Tbird. Need rotors for cobra 11.65". T bird calipers and pads. Need mustang wheels.
    SCARlit on drag duty now
  13. #163
    Aug 2018
    3
    Thank you very much for the information.
    If I do buy the Mustang hubs, should I also buy the hub rings from Dave? I assume these rings are needed to secure the Mustang hubs in the T-Bird rear spindles?
    Thank you again.
  14. #164
    Madison, Ohio
    17,600
    Thank you again.
    That is correct. You will not need the hub rings.
    Email me here.
  15. #165
    Aug 2018
    3
    Confused.
    I WILL need the hub rings with the Mustang hubs or
    I will NOT need the hub rings with the Mustang hubs?
    Thank you.
  1. Cobra rear brake calipers
    By XR7 Dave in forum Technical Forum
    Last Post: 09-29-2009, 12:14 AM
  2. FS: Rear cobra brake conversion brackets
    By Turbo351 in forum Super Coupe Club of Ontario
    Last Post: 04-04-2005, 01:07 PM
  3. Rear brake caliper park brake shaft seal?
    Last Post: 05-21-2003, 10:34 PM
