XR7 Dave
Picking up brackets from the coater's today. Coating this time around is clear/grey.
Grinding of the calipers brackets and spindles is mandatory no matter who made the brackets due to the amount of offset required. If you have to clearance a bolt to clear the brake cable it may be something to do with thickness of your brake pads. I have not had that issue before but it is very close and the E-brake arm that the cable attaches to does move, so if you have a clearance issue the only thing I can say is you may have to clearance that bolt head some as you already determined.
I may look into a lateral offset next time around, if it will clear the spindle that might be a solution too. In the mean time, you'll just have to clearance things.
Hub rings are $18 shipped by themselves.
