blue94sc
My 94 has been sold. Sad to see her go. But she's in good hands.
For sale, my 1994 SC. The car has 203000 estimated miles (the odometer quit at 196399 and I have been loggin the miles manually). It is moonlight blue with grey leather interior. My plan was to begin the rebuild process but because of a seperation/divorce I have to sell it. I purchased it in 2004 with 139100 miles on it from a friend at work. It has been in two minor accidents at the passenger rear. No damage was done to the frame or suspension. This car could have potential or could be a donor car for another project. Here are the goods/bads;
Goods;
Replaced plugs and wires back in 2005 with Taylor wires Autolite platinum plugs
Walbro 255 lph fuel pump
Replaced upper & lower front control arms
Replaced both strut rod bushings
Solid rubber engine and transmission mounts
Urethane rear shock bushings
Urethane differential bushings
Gator back belts
B&M Ripper Shifter
Teflon IC gaskets
Cold air intake kit with MP heat shroud
Sony 45w x 4 head unit
Amplifier bypass harness to run radio direct to speakers
Blaupunkt rear 5x7 speakers
X-site 5x7 front speakers
Recent coolant and thermostat change
Doesn’t burn oil or coolant
Drives good and straight. Engine still strong
E-brake works but needs adjusted
Heater controls and AC still works
All other controls work fine (locks, mirrors, windows, lights, seats …etc)
Early model rims in great shape. Plus an extra early model rim
Still have the aluminum space saver tire
Bads;
The clutch needs replaced. Doesn’t slip but chatters
The transmission is really notchy but still shifts ok.
The drivers inner tie rod has a little play
The odometer is currently broke but I’m willing to fix and correct the mileage
The speedometer sometimes sticks at low speeds. I would fix this along with the odometer.
The shocks are worn. The auto ride works great.
The body is starting to show some rust in the rockers and the rear panels
Bottom edge of driver side door getting bad
The sliding sunroof sometimes leaks. I haven’t been able to find out why yet.
Recently discovered the passenger side headlight has a broken tab
Various paint chips and clear coat spots
I am asking $1000. This has been my favorite car I have ever owned. It has NEVER left me stranded or broken down, just the minor issues with an SC. This was my go-to work car. Mileage is mostly highway. 40 miles a day round trip for work.
Goods;
Gator back belts
B&M Ripper Shifter
Teflon IC gaskets
Bads;
