View Poll Results: B&M Ripper vs Shifter Rebuild
Voters
32. You may not vote on this poll
  • B&M Ripper
    26 81.25%
  • Shifter Rebuild
    6 18.75%
Results 1 to 15 of 15
Thread: B&M vs rebuild.
    Apr 2011
    Romeo, MI.
    69
    B&M vs rebuild.
    The title says it all, for everyone else with a "sloppy shifter" which do you prefer to fix it.
    By the way, I see supercoupeperformance has more in stock.
    Aug 2010
    Pennsylvania
    91
    The short throw shifter makes a world of difference and B&M makes a great quality product. Now I don't have to waste my time trying to find the gear I want I'd recommend it to anyone
    Jul 2004
    Fresno,CA
    54
    I'll be replacing the shifter the weekend before the 4th of July. Already ordered a B&M Shifter because that is what I could find. I since learned this week that a kit is available for the M5R2 in the F150 and Ranger, and all we have to do is drill 3 holes to get the new seal to fit on our M5R2. I might try this- I want the car to retain its stock personality.
    Aug 2004
    Batavia,OH
    2,019
    The shifter is not some huge undriveable change, just a tighter action. I wouldn't worry about it being too much for you it is not that bad.
    Alan
    NYC
    17,431
    I heard that all peices needed fo rrebuild are not available and some need to b emodified...Love to see how it turns out if you try a rebuild...
    Greenville, IN
    4,329
    At the current typical prices for the B&M's, I'd have to say a rebuild is the way to go (assuming you can find the right parts).
    Matt Haub
    Apr 2011
    Romeo, MI.
    69
    B&M it is,
    I would love to try and do a rebuild but I don't have the time. The nice thing is that the B&M looks pretty durable (other than the dust boot.)
    Apr 2005
    Central Texas
    229
    The B&M is an improvement over a good stock shifter. Shorter throws and a more positive feel. Now if you have a worn out stock shifter the B&M will feel like a huge improvement. Rebuilding the stock shifter is not that hard, and yes the dust cover needs some slight modification to work as the correct parts are no longer available.
    Harmless flakes working together can unleash an avalanche of destruction.
    Mar 2006
    Delta, BC, Canada
    624
    All you have to do to the F-150 dust boot cover is oval the holes. here's a pic of the one that's gone on my tranny that' going in next weekend.
    The other parts were available from Ford when I rebuilt my shifter a couple of years ago.
    Regards
    Sean
    '91 White 5-Speed
    Greenville, IN
    4,329
    That boot looks more durable than the original style anyway.
    Matt Haub
    Jul 2004
    Fresno,CA
    54
    Sdw- thanks for posting that picture. That looks easy enough to oval the holes. I know for the other parts, following the suggestion by others, go on ebay and put in 'M5R2' the less than $20 rebuild kit will come up.
    Mar 2006
    Delta, BC, Canada
    624
    i looked at those repair kits but I'm not sure they have everything. I don't have a picture of the new parts but hereis a pic of the broken bits that I replaced.
    In the kits I don't see the two spring washers that you see broken here.
    Unless I missed something, which at my age is possible.
    Regards
    Sean
    '91 White 5-Speed
    Aug 2004
    Batavia,OH
    2,019
    The washers are in the kits, I have bought a few. Just had to do my ranger and a friends f150.
    Alan
    May 2006
    Chicago, IL
    920
    I've got an SC with one of each, I rebuilt one shifter with slightly higher price than the $20 kit. Went together fine works like a charm, went to rebuild another one withb the cheaper kit and after assembling it the same way it dodn't have the throw necessary to use. Since I don't need it for a car I've just left it alone for now. IIRC the kits don't include the spring washers, just large thick washers.
    I agree at $250+ for the B&M I'd sure rebuild the OE part first to see if it satisfies, but if you got the jack and you want the shiznit pop for the much better B&M part!
    3 SC's over a pair of SHO's ...
    Plat O Ribs Full House of SVT!
    SCCoA Member#: 3251
    May 2009
    46
    Talking Shifter rebuild
    I know this thread is old, but ironiclly in rebuild my shifter about the same time this poll started. I used all stock ford parts. The only thing I couldn't find was the dust boot. I used one for the truck and modfied the holes.
    I have had no problems with shifting even when shifting hard.
    I let the original owner drive it and he smiled as he said it felt like it did when it was new. Cost me about $75. It was worth it!
  1. Needing Tranny Rebuild help
    By thundrburd in forum Technical Forum
    Last Post: 05-15-2011, 08:18 PM
  2. Tranny Rebuild Kit/ B&M Aluminum Tranny Pan
    By jc91sc in forum Parts for Sale
    Last Post: 04-28-2005, 05:05 PM
  3. 8.8 Differential Rebuild Kits:
    By Rich Thomson in forum Technical Forum
    Last Post: 06-22-2004, 07:46 AM
  4. Replies: 4
    Last Post: 05-21-2004, 01:21 AM
  5. AOD Tranny rebuild kits...
    By tbirdman in forum Technical Forum
    Last Post: 05-15-2004, 12:33 AM
