Under Drive pulleys--- do u need any pulley pullers?
layinthesmack31
i just got my set of underdrive pulley's and i was wondering if u needed to use a pulley puller to get the alternator pulley off? i know that the crankshaft pulley and water pump pulley will bolt off but the alternator pulley is the one that confuses me. please let me know what i need to do to get it off. thanks
Matt
thats what i was wondering because i seen that but i didnt know if that was like the SC pulley where u take the nut off and then still need to have a puller. i just wanted to know before i got into so i knew what i needed.
Matt
Your most likley going to need a good impact gun with a swivel to break the alternater pulley nut loose. They are very tight. I have underdrives on both of my SC's and thats how I got the nut's loose. Since you won't be able to get a straight shot at the nut unless you remove your intercooler (not necessary) you'll need the swivel.
