XxSlowpokexX
Another Super Turbo Coupe
ehhhhhhhhhhhhhhhhhhhhhhh I am staying away from having just another...Go big or go home I was told
85mm TB. Return spring was weak so anexternal one was retrofitted. How does $200 sound? Or make a serious offer
Sorry to disappoint, but the 475rwhp number came on what is better known around here as the "Heartbreaker" dyno, no fudging required.
Iraaaa.....No deleting allowed!
He does that alot. I think its a new york thing. Speaks before he thinks.
Hey Damon, Cleanout your mailbox
Thanks, I sorta figured the springs would b a bad idea after you described your "storage" system I got caught by a couple suprize bills as of late, which burned the SC toy budget pretty bad so I think I am gonna stay out of the engine for now. Kinda sucks cause I know I'll end up doing it sooner or later, Only it'll be double the work. Why don't you like the Scorpion RRs? Even with no ratio change, and stock cam they should be good for less friction, which = more power & less heat. Just not enough to b worth the $$$?
Thanks
Adam
Nah, it has nothing to do with geography. It's age related. It's what happens when you reach the point where you don't give a damn about being politically correct or being bothered explaining everything you say
You don't get it, too bad. I know what I meant
Ira
I was going to make a comment about his great dyno number that day but if I remember correctly he spent more time running around trying to buy a useable set of plugs then he did on the dyno!!
Ira
My poor car.....just sayin.....
Everything is sold for the most part. I will need to look around to see what else is left
I know where you are Tony!
