Results 1 to 6 of 6
Thread: no start after new starter
    Dec 2003
    Beaumont, TX
    741
    Car died at lowes the other day. Wouldnt even try to crank. Battery was charged. Pulled it home and installed new starter. Started right up but when I tried to start it again yesterday, I turned the key and it just made a clank noise. Just one "clank" everytime I bumped the key. It started on the third try. I turned it off to see if it would start up again but it now it just clanks. What gives? 95 auto
    Jun 2008
    So. Calif.
    86
    Defective starter.....
    Dec 2003
    Beaumont, TX
    741
    I wasnt sure if there was relay i missed somewhere besides the one in the fuse box
    Jul 2006
    Escondido CA
    468
    Could be starter solenoid on inner driver side fender.
    20,948
    What you are describing is commonly caused by a loose connection of the trigger wire on the starter. It's the smaller wire with the spade connection. If that's what it is, you just need to unplug the wire, crimp the female connector with some pliers for a tighter fit and reattach the wire.
    Dec 2003
    Beaumont, TX
    741
    The new starter came with that wire already connected to it and I had to cut off the old connector off and crimp them together. I guess I need check the new wire where it meets the starter and see if its making good contact.
  1. cranks but wouldnt start
    By BuRHan90SC in forum Technical Forum
    Last Post: 07-21-2009, 12:43 AM
  2. Starter contacts / replacment starters
    By kendall221 in forum Technical Forum
    Last Post: 03-10-2009, 07:15 PM
  3. car no start, battery good, bad starter maybe?
    By 35th_tbird in forum Technical Forum
    Last Post: 06-06-2005, 11:04 AM
  4. Ford put a new engine in my SC, now it won't start
    By OKThumper in forum Technical Forum
    Last Post: 01-29-2003, 08:13 PM
  5. Need help ASAP...... Problem with starter......
    By EdmontonSuperCoupe in forum Super Coupe Club of Western Canada
    Last Post: 05-20-2002, 01:38 PM
