Results 1 to 10 of 10
Thread: '96 brakelight/shifter problem
    Jan 2012
    Dunnellon,Fl
    10
    Hello,
    I used to be here a few years back. I then had an '89 SC.
    Anyway. My current problem.I now have a '96 LX with 72k+ miles.First I noticed that I couldn't get my shifter from park to drive.I realize you need to apply the brakes first to get out of gear.The only way now is to turn the key aprox. 1/4 of the way between off and run.Pull selector to neutral then start and move to reverse or forward. I also recently discovered I don't have brake lights.I'm wondering if these problems are related? Since no brake lights shifter lock won't disenguage? Or is this a really weird concidance?
    Thanks for the help glad to be back!
    Bryan
    Aug 2011
    Kansas City, KS
    1,141
    I would say your right on. The brake switch is probaly bad.
    May 2009
    Crystal, MN
    405
    I would also agree that would be a good place to start.
    Jul 2005
    Clarksville, TN
    1,777
    Just did this
    You are right on the money. My wifes 94 SC just did the same thing, would not go out of Park and I had no brake lights.
    Switch is $5.99 at my Autozone here in TN, so it should be close to that where you are.
    Smitty
    Venetian Blue 1995 5 Spd...............No ET
    Orange Crush Pearl 1995 Auto SC........TBD
    506.30 rwhp, 545.37tq
    Garage:http://www.sccoa.com/forums/garage_v..._vehicle&id=13
    Jan 2012
    Dunnellon,Fl
    10
    Thanks for info!
    Jul 2009
    Sao Paulo, Brazil
    69
    I think my switch is pretty different from this one. Could anybody take a picture form it installed under the dash?
    Mine:
    http://imageshack.us/photo/my-images...sc00550pu.jpg/
    If it is not OEM, as I guess, is it the same bracket?
    Jan 2010
    Bossier City, LA
    2,232
    Quote Originally Posted by Rodolfo View Post
    Mine:
    The one you have pictured here is like the one I have, and I've seen on all the MN12s in the boneyard.
    Doesn't mount to the bracket, it's actually the linkage between the rod to the master cylinder / vacuum booster and the pedal.
    The rod fits through this and through the rod from the MC/booster, and this is what the pedal actually pushes!
    Check where the pedal and the MC/booster rod meet, and see what is there.
    Also, that's not a standard Ford harness setup ...
    RwP
    Jul 2009
    Sao Paulo, Brazil
    69
    RwP
    Tks! Can you send a picture to me? IŽll fix it.
    Jan 2010
    Bossier City, LA
    2,232
    It'll be a few days - may be better to have someone else post a pic (Ruby's currently sitting awaiting new injectors. I pulled two out in pieces when I went to clean them ... geez, wonder if THAT was why I had a severe 2-cylinder miss! *sarcasm* )
    Hmm ... not an exact picture, but this is close: http://www.2carpros.com/forum/automo...tch_ford_1.jpg
    This one may make clearer what I mean: http://ww2.justanswer.com/uploads/dr...0_193410_1.gif
    On the second one, "A" would be the brake light switch itself.
    I'll see about getting pics in a few days - gotta help the stepson fix his truck (his Escort now sounds like marbles bouncing around in a BIG metal can when he tries to crank it - Methinks his motor is toast.)
    RwP
    Jul 2009
    Sao Paulo, Brazil
    69
    Thanks!!!!
  1. Stock CD player/Radio problem, PLEASE HELP!!!
    By dbledown00 in forum Technical Forum
    Last Post: 06-22-2013, 12:39 AM
  2. HELP with misfire problem
    By trench in forum Technical Forum
    Last Post: 09-23-2007, 11:41 PM
  3. Head Light problem, need help A.S.A.P. Please
    By SC90_Pete in forum Technical Forum
    Last Post: 01-10-2005, 06:11 PM
  4. AOD Shifting Problem...
    By tbirdman in forum Technical Forum
    Last Post: 08-08-2003, 09:43 PM
  5. New or Still Old Problem
    By T1Bird in forum Super Coupe Club of Ontario
    Last Post: 06-30-2003, 10:09 AM
