David Neibert
SCCoA Admin
That is why the heads are getting filled. To prevent them from lifting. The LS guys run into this since they only have 4 bolts per cylinder too. And if flow is your concern, then the 38 lbs of boost the F1R is capable of will solve that!
So even with 38 pounds of boost you can eliminate the intercooler when using methanol for fuel ?
