Page 1 of 9 12345 ... LastLast
Results 1 to 15 of 135
Thread: Fuel Cell/Pump Pics
    May 2004
    Va. Beach,Va.
    7,002
    Fuel Cell/Pump Pics
    I'm getting ready to install a fuel cell in the trunk and I'd like to see how the few on this site mounted their fuel pump. Underneath the trunk is what I want to see, thanks.
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    '90 SC AUTO - Bone Stock
    May 2003
    Omaha, Nebraska
    6,207
    Quote Originally Posted by nickleman60 View Post
    No in cell fuel pump?
    Ken
    93 SC Whipple powered 11.648 @ 119.6
    Twin Turbo, air intercooled..yet to see
    May 2004
    Va. Beach,Va.
    7,002
    Quote Originally Posted by kenewagner View Post
    Ken
    Mine will be external. I know it should be mounted at least even or below the outlet of the fuel cell.
    SCCOA Member #2406
    Nov 2004
    butler pa
    1,926
    Since your car see alot of track time, I would mount the pump behind the cell also. The pump does not pull the fuel well especially when launching. Many people overlook the effect g forces have on the fuel system.
    https://www.youtube.com/watch?v=7bNS...e_gdata_player 10.070 video
    Best ET to date 10.070
    Best MPH to date 130.51
    best 60' to date 1.312
    MPX blower/ NO NITROUS!
    Karns, TN
    1,328
    Mine is external to the cell.
    Mike
    1989 Cougar XR7 - [I]Modified[/I]
    1967 Cougar XR7 - untouched -
    2011 F350 Crew Cab Superduty FX4
    6.7 diesel 435hp/800 ft lbs torque
    2010 Harley Davidson Ultra Classic
    1965 Factory Five Challenge Road Race Cobra
    May 2004
    Va. Beach,Va.
    7,002
    Quote Originally Posted by Kevin Leitem View Post
    Makes alot of sense. I wanted to mount the cell as far back as possible to eliminate clearance issues with the sway bar. Since my 10 gal. cell is 17"x17"x9" I do have 2"-3" clearance from the sway bar that I could utilize to allow the pump inlet to be further back than the oulet of the cell.
    SCCOA Member #2406
    May 2003
    Omaha, Nebraska
    6,207
    My pictures are on my computer at work. I will post some tomorrow
    Ken
    Nov 2004
    butler pa
    1,926
    i have the rear metal inner bumper removed. that is where i have mine mounted
    East Hartford, CT
    3,468
    I made a bracket for the pump that hangs off of the frame rail so that the pump in located between the fuel cell and the frame rail.
    Brian Oatway
    '94 SC 2.6KB C4 Auto
    9.956 @ 135.12 mph 1.364 60'
    514rwhp/460rwtq
    "Super Uber Club Member" - per Ira
    SCCoA Member # 705
    May 2004
    Va. Beach,Va.
    7,002
    Quote Originally Posted by SCrazy View Post
    Pics please...............
    SCCOA Member #2406
    East Hartford, CT
    3,468
    http://www.sccoa.com/forums/showthre...=115393&page=4
    post #49
    Brian Oatway
    514rwhp/460rwtq
    SCCoA Member # 705
    May 2004
    Va. Beach,Va.
    7,002
    Thanks Brian, is the top of your cell even with the trunk floor or raised? I was going to raise mine 2" so that it doesn't sit low enough to see the sump connections below the bumper. I want it to be invisible from outside of the car.
    SCCOA Member #2406
    East Hartford, CT
    3,468
    Mine is raised....sounds very similar to what your doing. Shoot me your email address and I'll send you a bunch of pictures.
    Brian Oatway
    514rwhp/460rwtq
    SCCoA Member # 705
    May 2003
    Omaha, Nebraska
    6,207
    I didnt take a lot of pictures. Mine sits below the floor as I wanted complete stealth. It also give me a full trunk space. You can not see it or the filter, pump from the outside from behind. Of course I built mine to fit and you wouldnt have that option from an off the shelf cell. I have mine bolted on the outside of the rail rather than the inside like Brian did his simply because the cell was built to fill that whole area. I made a pinch clamp for the pre filter to attach to the sump than a SS braided line to the pump. I fabbed a heat shield around it since the mufflers are right close. The post filter is further up where the old fuel tank was. Gives me excellent access to clean it out and it too has a pinch clamp to hold it in place. I dont really like all the busyness of it back there but it is what it is
    Ken
    Mar 2009
    chesapeake va
    195
    we got one on the mustang you can come look at if that would help ya
    edit* an external pump not a fuel cell. ours is sumped and a external pump
  1. Racetronix fuel pump wiring harness - install pics?
    By Pablo94SC in forum Non Technical Forum
    Last Post: 03-25-2010, 10:38 AM
  2. 6-65# Flow match fuel injectors and FP Regulator PICS ADDED
    By Wzenheimer in forum Parts for Sale
    Last Post: 10-25-2008, 04:24 PM
  3. Fuel Delivery
    By Magnum Powers in forum Technical Forum
    Last Post: 08-04-2008, 04:32 PM
  4. Modified Fuel Rail ?
    By SCrazy in forum Technical Forum
    Last Post: 07-19-2005, 11:42 PM
  5. Fuel pressure vs. Injector flow rate
    By Slysc in forum Technical Forum
    Last Post: 06-21-2005, 10:47 PM
