Page 9 of 9 FirstFirst ... 56789
Results 121 to 135 of 135
Thread: Fuel Cell/Pump Pics
  1. #121
    Jul 2003
    Ottawa, Ohio
    5,400
    Quote Originally Posted by 90sc35thann View Post
    LOL. We should be very upset with these Ford engineers. LOL They didn't do us any favors.
    ........... I'm a Ford engineer, in engine manufacturing not system design though.
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
  2. #122
    Jul 2003
    Ottawa, Ohio
    5,400
    double post
    SCCoA Member#: 2515
    11.676 @ 121.35 mph
    506hp/478tq
  3. #123
    Jul 2003
    Ottawa, Ohio
    5,400
    double post
    SCCoA Member#: 2515
    11.676 @ 121.35 mph
    506hp/478tq
  4. #124
    Manchester, NH
    2,064
    double post
  5. #125
    Manchester, NH
    2,064
    Quote Originally Posted by kenewagner View Post
    Your first statement was it is the biggest restriction, for me that is likely correct at this time but since it provides me with adquate fuel to the 60lb injectors while using a 2.3L twinscrew and making over 400 rwhp, I doubt most will find the fuel rail restrictive at all. A statement like that can lead sombody to think they need to up grade fuel rail and in reality could spend money in better places. I think Ryan was making over 440 rwhp with the stock rail. So in general thinking I dont see the the fuel rail as a problem restriction. Now if you want to look closely at the stock lines running under the car, they look really restrictive.
    If you are running #60 injectors X 6 = 360 pounds of fuel an hour. If fuel weighs about 6.07 pounds per gallon. That said each injector will flow 9.88 gallons per hour. 9.88 x 6 = 59.28 gallons per hour. Of course I am assuming you run at 100% duty cycle. So let's de-rate that to 90% and you get 53.35 gallons per hour. Divide that by 60 seconds and you get .88 gallons per minute. I guess the biggest question is will our stock fuel rail flow roughly a gallon of fuel per minute at 60 psi. if so then you are good.
  6. #126
    Manchester, NH
    2,064
    Quote Originally Posted by rzimmerl View Post
    The engine building is just fine. :-) My ecoboost F-150 isn't making any noises or leaking any fluid. We are good.
  7. #127
    5,106
    Quote Originally Posted by nickleman60 View Post
    The last thing I had to do was get the stock fuel gauge working with the new fuel cell. The cell came with a 0-90 ohm sending unit which we all know isn't the correct range, even so with a full tank (10 gal.) the gauge would read between 1/4 & 1/2 tank. I searched on here and found that the stock sending unit has a range of 18 to 160 or somewhere close to those ohm numbers. The closest I could find was a universal sending unit with 10-180 ohm range. I removed the extension bracket so it would be shorter than the 9" cell depth, it ended up being 6.5" long. Figured out how long the float needed to be to touch the bottom and top of tank, cut it and mounted it in the cell. Now the fuel gauge reads full to empty. I know it will be off some because of the slight difference in ohm ranges but I can live with it.
    http://www.ebay.com/itm/190667650820...84.m1497.l2649
    Glad you found that Keith. I looked months ago but couldn't find anything close.
    SCARlet on drag duty now
  8. #128
    May 2003
    Omaha, Nebraska
    6,175
    Math was never a strong point of mine. I beleive the restriction in the fuel line is not the fuel rail. I beleive it is the lines running under the car. The fuel rail looks to be 3/8" in diameter but the lines under the car from the fuel tank look to be about 5/16" ID. Most of the guys that have done major upgrades did the pump first, than voltage upgrade to the pump, than fuel lines to the fuel rail. So I feel the fuel rail is adquate for a high performance SC. With the new thing being 80lb injectors, 95 MM TBs and so on and so on. The fuel rail will probably be a needed upgrade.
    93 SC Whipple powered 11.648 @ 119.6
    Twin Turbo, air intercooled..yet to see
  9. #129
    Manchester, NH
    2,064
    The rail is 5/16 ID feed with a 1/4 ID return. There are points on the rail where it narrows down further as the bends are kink style bends. You will certainly achieve less frictional loss by replacing the lengthy skinny fuel line from the trunk to the rail and you will also have less pressure loss to the rail but then you are right back to using a 5/16 ID fuel rail.
  10. #130
    Home of the Whopper
    3,415
    That looks really nice Keith - good job. I have to ask though, do you ever put anything in your trunk? I'm just wondering about stuff rolling around in there.
  11. #131
    May 2004
    Va. Beach,Va.
    6,951
    Quote Originally Posted by Micahdogg View Post
    yes I put stuff in the trunk...........gas and nitrous.............
    SCCOA Member #2406
    '94 SC AUTO - $$$$ Pit
  12. #132
    20,909
    The stock rail will flow enough fuel to make over 500 rwhp using gasoline and large injectors with a voltage boosted 255 lph high pressure pump and stock fuel lines. Chris Wise's 4.2 turbocharged SC had this setup and ran 10.6 @ 130 on drag radials.
    Most of the people making over 400 rwhp are using modified stock rails that have a 6AN fitting attached to each end of the rail (inlet & outlet) then use a remote mounted regulator. Feeding each rail (3 injectors) with a 6AN supply hose will provide plenty of fuel for just about level of power you are likely to reach with a roots or twin screw blower.
    I think bigger rails should be considered when using E85 and trying to exceed 450 rwhp with a roots or twin screw blower, because of the additional 30% of fuel volume required compared to using gasoline at the same power level.
  13. #133
    May 2003
    Omaha, Nebraska
    6,175
    The fuel line does constitutes the biggest restriction in the system for flow. Its a smaller ID size than the fuel rail. The fuel rail as is well support lots of HP if you get the fuel to it. Thats why the first recommendation eveyone makes is a bigger fuel pump. Second recommendation would be larger fuel lines to the fuel rail and than last of all custom fuel rails. I cut a section of fuel line and took a picture of it next to a fuel rail that is cut to extend it for a bigger blower. Daddy always said a picture is worth a 1000 words.
  14. #134
    5,106
    Keith, or anyone else with a cell. When they give you measurements is the sump included in the depth or is that extra? Say the measurements are 17x17x9, the 9 being how tall or deep it is, is the cube part 9" deep and then the 2" sump is 11" from the top of the tank?
  15. #135
    May 2004
    Va. Beach,Va.
    6,951
    The sump is extra depth Chris.
    SCCOA Member #2406
  1. Racetronix fuel pump wiring harness - install pics?
    By Pablo94SC in forum Non Technical Forum
    Last Post: 03-25-2010, 10:38 AM
  2. 6-65# Flow match fuel injectors and FP Regulator PICS ADDED
    By Wzenheimer in forum Parts for Sale
    Last Post: 10-25-2008, 04:24 PM
  3. Fuel Delivery
    By Magnum Powers in forum Technical Forum
    Last Post: 08-04-2008, 04:32 PM
  4. Modified Fuel Rail ?
    By SCrazy in forum Technical Forum
    Last Post: 07-19-2005, 11:42 PM
  5. Fuel pressure vs. Injector flow rate
    By Slysc in forum Technical Forum
    Last Post: 06-21-2005, 10:47 PM
