I have a 1992 Super Coupe (3.8L V6 w/ manual transmission). There is a neutral safety or clutch interlock switch (Ford Part no. 1C3Z11A152AA) on the clutch that operates via a push rod (Ford Base Part no. 7R537), which has a plastic orientation clip and pivot (Ford Part no. E9SZ9D816A) at the other end of the safety switch. It is the plastic orientation clip and pivot that I need. Ford no longer makes this part.
The part numbers come from a Ford diagram titled: "1992 S (Thunderbird), 70 - Standard Transmission, Clutch, EXTERNAL PARTS, Clutch and brake pedal". The diagram also has the number "P-21778" and the date "2/15/99" in the lower right.
(The clutch interlock switch is generally available, but it does not come with the orientation clip and pivot.)
